Oil filter brand --- Which is the best?
- mariozappa
Re: Oil filter brand --- Which is the best?
12 Oct 2005 12:50
Holy cow!
I've got that tick, tick with the Fram filters too!
:pinch:
:pinch:
1977 KZ650C1
and the KZ650/KZ750 Conversion
- rivman15
12 Oct 2005 13:42
Wix Filters. If there good enough for Nascar then there good enough for me! Riv
- patmann
13 Oct 2005 06:39
rivman15 wrote:
I don't want a filter that only works when you drive around in circles like your lost;)
nascar?? Guess I'll go to the AC Delco filters for sure!!Wix Filters. If there good enough for Nascar then there good enough for me! Riv
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
- patmann
13 Oct 2005 06:40
- 1973Z
13 Oct 2005 07:42
Aside from using Fram in a bike, I have been using them a in a 1986 Toyota Tercel (Fram # PH2951)for the past 230,000 miles. Should I be worried? I have a lifetime supply of Z1 filters I ordered through a friend who had a dealer number so I got them wholesale about 20 years ago and I don't even know what brand they are. I change oil and filter every thousand miles on the Z1 using Castrol GTX 20w-50 or 10w-40 dependening on the season. The bike will turn 68,000 miles this week end. I use generic 10w-40 in the Toyota and change oil and filter every 2,500 miles. Perhaps frequent changes are as critical as a good filter for long engine life. I am as surprised as the others above that Fram was found wanting.
- GargantuChet
13 Oct 2005 08:42
I'd imagine that regular oil+filter changes would do a lot to mitigate the effects of a crappy filter. The linked article mentioned Fram letting dirty oil seep back into the pan, which probably means that some of the crap that's been stuck in the filter comes back out with it.
Regular oil changes should help to flush out the garbage, hopefully. As long as the filter is relatively durable and doesn't let dirty oil blow by, I'd think that regular oil and filter changes should help to reduce engine wear.
That doesn't mean I'll keep using Fram, but it does mean that I won't feel too bad about having used Fram in the past.
Who carries the Wix filters?
13 Oct 2005 19:45
Here's a very detailed comparison of filters:
www.shoclub.com/lubrication-oil/lubrication-oilpart1.htm
and here's where I buy my K&N oil filters at a great price:
www.ronayers.com/catalogs/pu/parts.cfm?t...25&secid=23&type=327
BTW, I agree that frequest oil & filter changes are probably more important than the brand. Hope this is helpful.
Ed - Original owner KZ650C1
