help oil leaking around exhaust pipe/engine
- allanworks
05 Jun 2011 21:01
i just noticed that theres oil coming out at the bottem of the header where it bolts to the engine. its not much about 2 table spoons worth in an half hours worh of riding. she doesnt smoke.so im confused some body told me to pull my header off and replace the exhaust gasket and a o ring thats sapposed to be in there.but my kawasaki service manual doesnt say anthing about exhaust o rings or i cant find it.its a 1978 kawasaki kz750 twin and cant ride till i fix it.
- racer54
Re: help oil leaking around exhaust pipe/engine
05 Jun 2011 21:36
Is it the oil ring in the tach drive? If that o-ring goes bad, it will leak oil aroung the drive. It will look like an exhaust leak. If it is leaking oil out the exhaust port, you have bigger problems! Check the tach drive...wipe the are off best you can and see if that's the problem.
- testarossa
06 Jun 2011 00:12racer54 wrote: Is it the oil ring in the tach drive? If that o-ring goes bad, it will leak oil aroung the drive. It will look like an exhaust leak. If it is leaking oil out the exhaust port, you have bigger problems! Check the tach drive...wipe the are off best you can and see if that's the problem.
+1
It's a common problem on these bikes.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- allanworks
06 Jun 2011 00:52
its not the tach drive .its coming out of the exhaust port looks like im gona have to rebuild the whole engine while i have her apart shes not very pritty bike but maby while i have her apart ill have her painted.this happend when i changed the oil i think i just bought her for $600 and the oil was black as can be.
06 Jun 2011 02:04Hello, allanworks, and WELCOME to KZr!allanworks wrote: ...oil coming out at the bottem of the header where it bolts to the engine...some body told me to pull my header off and replace the exhaust gasket and a o ring thats sapposed to be in there.but my kawasaki service manual doesnt say anthing about exhaust o rings or i cant find it.its a 1978 kawasaki kz750 twin....
Exhaust gaskets are available at Z1 Enterprises.
Click > www.z1enterprises.com/detail.aspx?ID=1882
- andy9802gt
- If it tastes that good, eat it yourself.
08 Jun 2011 05:49
Yeah!, if you don't change those exhaust gaskets all that oil that isnt supposed to be in your combustion chambers will leak out instead of getting burned up in the exhaust.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
