Cheech and Chong Smoke!
- halfrican423
04 Jun 2011 15:40
I have my 1980 kawasaki 1000 online here! i just rebuilt the engine and it is smoking like crazy! took everything off re adjusted all the pistons and rings and made sure they were correct! i am using chrome-moly rings! is it normal to smoke like it is? i honed the pistons out really really well! they fit very tight in there! Cannot get it to stop smoking!!!! Any ideas?
- KZQ
- Administrator
Re: Cheech and Chong Smoke!
04 Jun 2011 16:08
Hi Hal,
I'm no engine builder but chrome moly steel is typically used for bike frames. I think your rings are molybdenum coated iron.
In any case, how long have you run it? What sort of piston clearance do you have? When you adjusted the pistons and rings did you consider that some of the rings have a top and a bottom?
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- halfrican423
04 Jun 2011 16:14
not sure what the clearance is on the piston rings! i know everyting was put in correctly my dad and i put it together and he has had multiple kz and is a mechanic! the bike runs very very strong! 10x better then the first time! i have about 60-70 miles on it! i was told that the rings i have will take 500 mi or more! i was just looking for some advice i am gonna go home and sit down with a six pack and just sit there and run the shit out of it!
- TeK9iNe
- What did you do!?!
04 Jun 2011 17:56
You have to make absolutely sure that none of the oil control ring is overlapping itself, (you know the one that is all zig/zaggy stepped).
Also, the valve seals should be in good order.
Perform a leakdown test...
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- otakar
04 Jun 2011 18:15
I have the exact same problem with my bike. I rebuilt it and it smokes. I don't feel like pulling the head and cylinders to check the rings again. I just said heck with it. What's a little oil. :silly:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Motor Head
04 Jun 2011 18:39
Read through this, basics from Hastings on honing.
www.hastingsmfg.com/ServiceTips/cylinder_bore_refinishing.htm
So if your cross hatch pattern is to shallow it could cause oil consumption. Then as stated the oil control ring, hopefully three piece, the expander has to butt end to end. Also the two thin rings should have the ends staggered. Ring end gap must be within spec. To big and there will be poor sealing. To small, especially on the top compression ring, can cause scoring in the bore or even seizure. How was the valve guides? Did you replace the stem seals? Even with no stem seals if the guides are within spec, the only noticeable smoke would be on downshifting and start up.
- peter1958
04 Jun 2011 19:16
Rings aint seated. Run the piss out of it for awhile.
www.kzzone.com/
- wireman
04 Jun 2011 20:40dont leave it sit there idling,thats a sure fire way to smoke an air cooled motor.halfrican423 wrote: not sure what the clearance is on the piston rings! i know everyting was put in correctly my dad and i put it together and he has had multiple kz and is a mechanic! the bike runs very very strong! 10x better then the first time! i have about 60-70 miles on it! i was told that the rings i have will take 500 mi or more! i was just looking for some advice i am gonna go home and sit down with a six pack and just sit there and run the shit out of it!
- wireman
04 Jun 2011 20:52
so what exactly was done to the motor? new piston kit and bore job or just rings/hone?
if you had to hone the hell out of it because pistons were too tight in bore that sends up lots of flags in my head.
did you measure the cylinder bores/pistons if it was just a re-ring job?
a stock kz1000 bore should be somewhere between 70 and 70.012mm measured at atleast 3 differant points inside of sleeve,and within like .01mm of each other .
piston runs 69.94-69.95 and actually gets smaller with wear to 69.8mm min
end gap on rings(stock)top/sec ring .3-.5mm,max of .8mm
if youre using aftermarket pistons you need to check the manufacturers specs
- lemo32
- The Price of Cool aint cheap
04 Jun 2011 21:18
X3 with what everyone has said, rings are also marked, always install with markings facing up, rings probably havent seated, but I would ride em in not idle em in.
1979 kz 1000 06 katana 750
- 82KZ305Belt
05 Jun 2011 00:09halfrican423 wrote: I have my 1980 kawasaki 1000 online here! i just rebuilt the engine and it is smoking like crazy! took everything off re adjusted all the pistons and rings and made sure they were correct! i am using chrome-moly rings! is it normal to smoke like it is? i honed the pistons out really really well! they fit very tight in there! Cannot get it to stop smoking!!!! Any ideas?
Faaaaaaaaaarrrrrrrrr oooooooooooouuuuuuut, maaaaaaannnnnnn.
81 KZ650 CSR
77 KZ650B (not in my paws yet)
82 KZ305 CSR
82 KZ305 CSR
- Old Man Rock
05 Jun 2011 12:27
Hmmm... Head work (valves, guides, SEALS) done?
OEM seals only way to go... And yes, I learned the hard way originally as well on that one...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
