Crankcase breathing
Crankcase breathing
02 Jun 2011 17:02
- wireman
Re: Crankcase breathing
02 Jun 2011 17:20
from what i understand of it hes just venting crankcase to atmosphere basically,same as when you replace stock airbox with pod filters.
race car engine builders have been running a hose from crankcase/valve cover vents to header collectors for years to help pull extra pressure out of engines to seal rings for as long as i can remember
02 Jun 2011 17:31
I think his system has both an intake and a valve-controlled vent, whereas the typical pod system has one little hose to do both.
- wireman
02 Jun 2011 17:37
didnt read that part,my head was hurting enough trying to look at the picture he posted! :laugh:
02 Jun 2011 17:39
- wireman
02 Jun 2011 17:45
heres a basic picture of what i was talking about,notice the fitting where the 4 tubes merge together into collector,that ties in with crankcase vent on each valve cover on motor with a hose
Attachment hedm_65018-e.jpg not found
02 Jun 2011 20:30
Cool, but is there an intake, or does this system depend solely on blowby? I'm guessing a backfire could be bad :blink:
- wireman
02 Jun 2011 20:46
theres actually some sort of check valve that screws on to the header,from what ive been told the exhuast does a good job of pulling it out.
helps seal rings better,next best thing to a vacuam pump
02 Jun 2011 22:39TexasKZ wrote: Ok you science and engineering types, what say you about this?
bunnbreather.bigblog.com.au/index.do
With this and an X-pipe, nobody could touch you, not even wireman on his turbo. :laugh:
- wireman
02 Jun 2011 22:43
well i probably better get back to work on it then! :woohoo:
