J head and frame...
  • racer54
  • racer54's Avatar Topic Author
J head and frame...
27 May 2011 23:07
#453908
If you have a J head on your KZ motor, can you remove the motor from the frame with the head on the motor? I have heard that the J head is taller and you have to remove the head so you have enough clearance to remove. Anyone have any experience with this?
  • toad
  • toad's Avatar
Re: J head and frame...
27 May 2011 23:28
#453913
I am wondering as well. I do not have the J head yet.
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
  • wireman
  • wireman's Avatar
28 May 2011 03:49
#453957
it will come out,had my motor out of my old 1327 out with j-style head on more than one occasion without removing the head from motor B)
  • ELCouz
  • ELCouz's Avatar
28 May 2011 11:22 - 28 May 2011 11:23
#453994
On my kz550 83 with a j head i had some trouble getting it out at angle (frame narrower than KZ750)
So we removed the head cover valve to give us a little more clearance and less weight.
Take your time doing this... don't force the engine if it doesn't go out easily!
You don't want to drop that baby on the concrete ! :)
regards,
laurent
1982 KZ810-R1 GPZ with hindle 4-into-1 pipe
Last edit: 28 May 2011 11:23 by ELCouz.
  • steell
  • steell's Avatar
28 May 2011 12:31
#454001
ELCouz wrote: On my kz550 83 with a j head i had some trouble getting it out at angle (frame narrower than KZ750)
regards,
laurent
You have a 550 with a 1000 motor in it???
I'd really like to see pics of that!
  • TexasKZ
  • TexasKZ's Avatar
28 May 2011 13:34
#454005
me too! :woohoo:
  • ELCouz
  • ELCouz's Avatar
29 May 2011 17:28 - 29 May 2011 17:37
#454206
oops, for all that time i thought that J head meant the 2nd head version (revision) past 1980 of any KZ 4-inline engines...
So i guess everybody talking in this forum about J head is talking about the KZ1000 J Series :O
Correct me if i'm wrong... but at least i think that i'm partially right... every kz engine past 80's bear similarities with the new introduced KZ1000 J series head...
Last edit: 29 May 2011 17:37 by ELCouz.
29 May 2011 18:45
#454218
ELCouz wrote: ...kz engine past 80's bear similarities with the new introduced KZ1000 J series head...
Here's a link to some good info:
Click > www.aperaceparts.com/tech/techkz1000.html
Good Fortune! :)
The following user(s) said Thank You: ELCouz
  • ELCouz
  • ELCouz's Avatar
29 May 2011 19:17
#454227
Thanks for the good article Patton !
Have a nice riding season ! ;)
laurent
