Loud clang while cranking
  • KZQ
  • KZQ's Avatar
  • Away
  • Administrator
  • Administrator
Re: Lound clang while cranking
04 Jun 2011 17:52
#455414
MatthewakaMatt wrote: One more question about fixing this. Where can I find the gasket for that side engine cover? Online I've only found complete engine gasket sets, and never just that individual gasket.
The gaskets are available from any Kawasaki dealer. I bet Z1 Enterprises sell them separately as well.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
04 Jun 2011 20:13
#455436
Which gasket do you need (see picture)? Ed
Attachment KZ7502.jpg not found
  • wireman
  • wireman's Avatar
04 Jun 2011 21:17
#455457
TeK9iNe wrote: You can use a liquid gasket maker just fine. Apply a very thin film with your finger to both very clean surfaces, then assemble as per the directions on your choice gasket maker.
The regular black stuff works fine.
B)
:woohoo:
  • MatthewakaMatt
  • MatthewakaMatt's Avatar Topic Author
04 Jun 2011 21:34
#455463
In that picture, I need gasket #4. I'll stop by the local Kawasaki dealer to get it then.
05 Jun 2011 00:11
#455497
You may find that gasket is no longer available. If so, here are a couple on eBay with thye pre-supersession part number:
motors.desc.shop.ebay.com/i.html?_nkw=14...06.m270.l1313&_rdc=1
  • MatthewakaMatt
Re: Loud clang while cranking
13 Jul 2011 23:02
#462735
I have been traveling for work, so I just got a chance to work on the bike again. The springs and guide tubes for the starter clutch were all broken. One of those broken guide tubes is stuck inside its hole in the surrounding assembly, and I can't get it out. There isn't enough room to get it with a tap or drill bit.
Any ideas on how to remove it?
  • elfmagic17
  • elfmagic17's Avatar
14 Jul 2011 00:32
#462754
KZCSI wrote:
MatthewakaMatt wrote: Thanks Bill. I guess that means I need to figure some way to remove the rusty, stripped bolts holding that cover on.
You can drill them out carefully. The repair is not difficult as long as the boss on the starter sprocket is not too worn.
Have you tried to bump start it?
Bill
If you can access the head of the bolt easily you can use a cutoff wheel to make a slot across the top of the head and go after it with a impact driver like this( www.sears.com/shc/s/p_10153_12605_009476...ockNo=2&blockType=G2 ) I've had very good luck with this operation.
Kenny Hicks
74 Honda CB550
