My first engine rebuild on a 1980 KZ1000 LTD
- jimmyjimmyjoe
- Hope Im ready for this build
DoctoRot wrote: I took the cylinder off and tried to remove the pistons. I got the circlips out but the wrist pin doesn't want to come out. The manual said to try heating up with a torch, that didn't work either, it also has a diagram for a home made puller. I'm gonna try and make it today and see if i can get those pins out.
So how did you end up getting the pistons off? Any pictures of the tool.
I also am about to take apart a kz1000p I just picked up a couple of days ago. I also have never build one before so I will be watching close and I hope you dont mind if I ask questions in your tread. Not trying to hijack your thread. Just in the same boat.
Thanks for all ive learned so far.
- wireman
- Thank you received: 299
Attachment brassrod.jpg not found
- DoctoRot
- Thank you received: 679
@wireman little confused here "use something soft like a brass drift and tap on it with a hammer to see if they move" are you talking about the valve guides?
@jimmyjoe I cant seem to find it at the moment but there is a pic of one in the clymer manual, i took a photo of it, when i find that thing i'll put it up here. I used a PVC pipe and no pad.
I picked up this solvent sink and started cleaning the engine cases
The gaskets are really stuck on there, my friend suggested i use a razor to slice them off, but because the aluminum is so soft, I seem to be slicing it as well. Is there some easier way to get the gaskets off? Then I remembered I read somewhere that its good to have all the mating surfaces machined down when you rebuild an engine. Is this true or did I make this up? I know you need the head resurfaced, but what about the top of the engine case, and between the cases?
- MFolks
- Thank you received: 540
- wireman
wrist pins from pistonsDoctoRot wrote: sorry for the lack of posts i have been out of town for a while, but im back now.
- jimmyjimmyjoe
Bye the way what all did you have done to the head and how much was it?
- DoctoRot
As far as splitting the cases goes, I thought it was easier than removing the top end, there is more bolts to remove but doesn't seem too much harder. Its the putting it back together stuff that gets complicated, but we shall see. The crank just lifts out once you split the cases, and i wanted to check the bearings to make sure they were all solid, I also dropped it off at a local motorcycle shop to inspect the crank to make sure its straight and there are no cracks.
I am also having M.R.E. undercut my transmission.
I have been spending my spare time prepping the engine cases for paint. Meticulously sanding every surface, either by hand or with these
they are great for sanding in the fins, probably other uses as well.
- DoctoRot
- DoctoRot
I also noticed the clutch springs had some wear on them. Should I replace these as well?
I finished ordering parts and they are on the way. I'm gonna try and finish up the engine cases today so i can start putting it back together.
- KZ_Rage
- Kentucky Bourbon Barrel Ale
- Thank you received: 19
I think you can dress that nick out without any issues.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
- racer54
- Thank you received: 114
- KZ-Izzo
Live Fast
1980 KZ1000 b4 ltd
