kz1100 LTD (83) Gas mileage?
  • pgrojean
  • pgrojean's Avatar Topic Author
  • Pete
11 May 2011 17:01 - 11 May 2011 17:02
#450333
I recently did a top end on my bike. Just returned from 1000 mile trip and I averaged only 31/32 miles to the gallon. Seem awfully low. Can anyone tell me what I should be expecting? bike runds great! But?? my Prius get way better milage.
thanks for help & comments.
peter
KZ1100 LTD - 83
R1200 C - 98
RD 250/350 73
KLR 650 - 06
XS 650 - 79
Last edit: 11 May 2011 17:02 by pgrojean.
  • hocbj23
  • hocbj23's Avatar
Re: kz1100 LTD (83) Gas mileage?
11 May 2011 17:18
#450335
How bad were u hammering it?My 82 KZ gets maybe 40 cruising around .These really arent economy bikes,but 30-31 sounds low to me.Done a good tune up to include valve adjust and carb synch lately?That might help.Checked tire pressure?Good luck and I am sure others here will have some good thoughts.bj
  • hocbj23
  • hocbj23's Avatar
11 May 2011 17:21
#450336
Bump. Sorry I missed the obvious--a 1000 mile trip?Wow.Thats impressive.Did u have the bike loaded down with lots of good wind resistant gear?That will whack ur mileage something fierce.bj
  • Topper
  • Topper's Avatar
11 May 2011 17:34
#450338
My '79 KZ750 twin seems to average about 40mpg if that provides any basis of comparison.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
  • pgrojean
  • Pete
11 May 2011 18:03
#450342
Attachment IMG_1746.JPG not found
Was loaded with gear which was not very aerodynamic. Bag, tent, sleeping bags, etc. and it was pretty windy in west Texas. Ran average of 70/75mph sometimes a bit higher. Valves and carbs were recently adjusted/sync'd. Seems to me I should be getting in the high 30's, anyway. Black soot in muffler may indicate "rich" running, would that make a significant difference?
KZ1100 LTD - 83
R1200 C - 98
RD 250/350 73
KLR 650 - 06
XS 650 - 79
  • hocbj23
  • hocbj23's Avatar
11 May 2011 18:22
#450348
Nice bike. Pipe coloration seems to indicate the bike is tuned pretty good and running about right.My Vance and Hines is always a little sooty so dont believe that makes much difference. Might pull a plug or two and check insulator color--if they are brownish-tan in color,no problem.If the plug(s) is black,sooty or oily looking,u may have a rich running issue.Are u running the stock gearing which I guess would be 15 tooth front,39 rear? Stock tires? 75 mph on a stock geared KZ means ur turning pretty good rpm.Loaded with gear and a headwind,my guess is that ur mileage isnt that bad.One other thought--how is air filter?Changed it lately? I see ur running stock air box as I am..bj
  • hocbj23
  • hocbj23's Avatar
11 May 2011 18:29
#450349
Bump. Sorry. If u take another long road trip,u might think about going up one tooth on your front sprocket OR down two teeth on your rear. This would allow u to cruise 75 mph without turning so many rpm.bj
  • Motor Head
  • Motor Head's Avatar
11 May 2011 22:53
#450401
I would think you should get mid 40's on the hi-way. I got 46 on my 1100 shafty, and 50 mpg on my 1000 LTD. They can get good mileage if set up right. Both have fairings and the LTD bags and was loaded etc for 3K + miles.
  • pgrojean
  • Pete
12 May 2011 12:53
#450493
I'm going to check the carb jetting and double check everything else. I guy I bought the bike from (original owner) had, at one time, four into one exhaust and KN air filters. which required re-jetting of carbs. He said that he had everything set back to stock when he put the standard exhaust and air filters back on, but now I'm not sure that he did. thanks for feedback.
pete
KZ1100 LTD - 83
R1200 C - 98
RD 250/350 73
KLR 650 - 06
XS 650 - 79
