crankcase all the same?
- DELAHUNT875
07 May 2011 16:39
HI ALL!! I have a 1981 KZ550A2 standard will all the 80-83 kz550 models be the same crankcase or do i have to find one from a kz550a2.
- kz750saskatoon
Re: crankcase all the same?
07 May 2011 18:06 - 08 May 2011 12:56
Oddly, the Kawasaki drawings for the kz550-a2 do not list the part number for the crank case. The 82 and 83 have the same one.
The pictures look identical between the 80-83.
Also, it might be useful to know that all the following bikes have the same crankcase as the 82/83:
[strike]KZ1000-J1 (1981)
KZ1000-J2 (1982)
KZ1000-J3 (1983)[/strike]
KZ550-A3 (1982)
KZ550-A4 (1983)
KZ550-D1 (GPz) (1981)
KZ550-H1 (GPz) (1982)
KZ550-H2 (GPz) (1983)
EDIT: DISCLAIMER: This list was generated using the Kawasaki parts diagrams. The 1000J crankcases simply have the same part number as the listed 550 crankcases. See the following posts that suggest these are not compatible.
KZ1000-J2 (1982)
KZ550-A3 (1982)
KZ550-A4 (1983)
1981 KZ750-H2
Saskatoon, SK
Saskatoon, SK
Last edit: 08 May 2011 12:56 by kz750saskatoon.
The following user(s) said Thank You: DELAHUNT875
Last edit: 14 Feb 2013 11:09 by martin_csr.
- otakar
08 May 2011 11:23
Whoa Whoa Whoa Are you saying that the KZ1000"J" series engines had the same crankcase as the KZ550????????????
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- DoubleDub
08 May 2011 11:48
That caught my eye also - is there a source for that?
- otakar
08 May 2011 12:14
Well, common sense would tell you that it's not true and in no way can be. Since the cylinder spacing is completely different between the two bikes. Even the 650/750 has different cylinder spacing. The width between the cases is not even close.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- kz750saskatoon
08 May 2011 12:52 - 08 May 2011 12:56
I should have been more clear that the list was from the Kawasaki drawings. It seemed very strange to me as well but I didn't know enough to completely remove it.
So disclaimer: the 1000J crankcase had the same part number only as the 550 crankcases.
I should have just looked at the picture, they are nothing to same.
1981 KZ750-H2
Saskatoon, SK
Saskatoon, SK
- zed1015
08 May 2011 15:00 - 09 May 2011 13:29
The Z500 and 550 fours are all based on the Z400/4 even the 550 Zephyr and Gpz550 too.
Lots of parts are interchangable.
Shouldn't be too many (if any ) crankcase differences throughout the range.
Z550 i think was a stroked 500 but been a while since i tinkered with one.
Was common over here to hop up 400's with 500/550 topends.
Vaguely remember that the 550 had taller barrels which had to be skimmed to work with the 400 cranks stroke to make a 500.
Last edit: 09 May 2011 13:29 by zed1015. Reason: add info
