kz650 and 750
- silverado
kz650 and 750
06 May 2011 22:25
Hi All will a kz750 engine fit in a kz650 frame without too many modifications? Thanks in advance for the help.
1980 kz 650 f
2 1981 kz550 ltd's
1 19?? kz750
2 1981 kz550 ltd's
1 19?? kz750
- Injected
Re: kz650 and 750
06 May 2011 22:34
The last model year of the 650 actually had 750 cases... no mods necessary.
1978 KZ650B2 modified project
- silverado
Re: kz650 and 750
06 May 2011 23:56
I have a 1980 kz650f not sure what year the 750 is but it has electronic ignition, I bought as a parts bike.
1980 kz 650 f
2 1981 kz550 ltd's
1 19?? kz750
2 1981 kz550 ltd's
1 19?? kz750
- steell
Re: kz650 and 750
07 May 2011 00:40 - 07 May 2011 00:41
You might have to change the plug on the end of the alternator, or just swap stators, and you'll probably need a new throttle cable. And you'll either have to use the 750 igniter, or swap over to the 650 points. Other than that it's a simple job.
Last edit: 07 May 2011 00:41 by steell.
