clutch noise
- 82KZ305Belt
clutch noise
06 May 2011 18:52 - 07 May 2011 22:04
I guess I need a better title-nobody is even reading my thread. Or do I have bad breath?
This is the sound my 305 makes when I depress and release the clutch when idling. Is it something I should be concerned about? I'm not an experienced rider so I dont know....I cycle through squeeze and release several times in the audio, You can hear it get louder when I release the clutch.
The audio starts and ends on louder parts with the clutch released and making the noise in question.
clutchnoise.mp3 - 0.21MB
81 KZ650 CSR
77 KZ650B (not in my paws yet)
82 KZ305 CSR
82 KZ305 CSR
Last edit: 07 May 2011 22:04 by 82KZ305Belt. Reason: to get a response
- 82KZ305Belt
Re: clutch noise
07 May 2011 23:11
bumparoni and meatballs
81 KZ650 CSR
82 KZ305 CSR
82 KZ305 CSR
- roy-b-boy-b
Re: clutch noise
07 May 2011 23:59
Is the ticking coming from your valves?
Have you put a piece of wood to your ear and the area you think the noise is coming from.
I'm almost deaf so maybe someone can hear better what the noise is. Roy
- 82KZ305Belt
Re: clutch noise
08 May 2011 00:36
The constant higher pitch ticking is the valves, I would say. The noise in question is more of a low rattle, and ebbs and flows during the recording as I depress and release the clutch.
Whatever it is is dragging because when the idle drops toward 1000 (separate issue we wont go into) and I release the clutch, it will sometimes kill the engine.
81 KZ650 CSR
82 KZ305 CSR
82 KZ305 CSR
- roy-b-boy-b
Re: clutch noise
08 May 2011 20:39
Has this bike been sitting for a while?
The clutch plates might be sticking and need cleaning. Roy
- 82KZ305Belt
Re: clutch noise
09 May 2011 14:34 - 09 May 2011 14:35
Well its 29 years old with only 7000 miles on it, so it sat somewhere at some point. But I bought it last July at 5000 and it hasn't sat since then, except during the snowy season. I noticed the sound last fall and its possible it came to me that way and I just didn't notice it until I rode it for a while.
81 KZ650 CSR
82 KZ305 CSR
82 KZ305 CSR
Last edit: 09 May 2011 14:35 by 82KZ305Belt.
- Cruez
Re: clutch noise
05 Jun 2011 23:16 - 05 Jun 2011 23:16
Just got one of the two running that I picked up the other day that have been sitting for a while also... it seems to be sticking .. will they eventually loosen up? or do I need to tear into them? There is also a rattle at idle down there. I noticed it first when I put it in gear it just stalled, with the clutch in. It seemed to get a little better after engaging the clutch a few cycles.
Last edit: 05 Jun 2011 23:16 by Cruez.
- testarossa
Re: clutch noise
06 Jun 2011 00:01
Clutch noise in multi-cylinder bikes is often a symptom of a bike that needs the carburetors properly synced with vacuum gauges. I know that a bench sync will get my KZ1000 running, but it needs a vacuum sync to have a smooth, quiet idle.
A video of my bike running, but needing a sync:
And one of it running when it had been synced before:
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- 82KZ305Belt
Re: clutch noise
06 Jun 2011 01:54
I should have come back and updated. You guessed it-My clutch sound went away completely after I cleaned my carbs a few weeks ago. I eyeballed the synch, but its humming along just fine.
81 KZ650 CSR
82 KZ305 CSR
82 KZ305 CSR
