Quality brands of gaskets?
  • Nelson
  • Nelson's Avatar Topic Author
06 May 2011 17:10
#449249
Hey I wanna buy a gasket kit for my 1000. Online there are various brands available and no-name brands. I don't want cheap junk that will leak. What are good brands to look for?
How can I tell if a "complete" kit really has everything?
Is a stock head gasket adequate for 10.25:1 1075 pistons?
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
Re: Quality brands of gaskets?
06 May 2011 17:21
#449250
Comedic is a good brand and a stock head gasket won't work on a 1075.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
  • wireman
  • wireman's Avatar
06 May 2011 17:28
#449252
cometic or vesrah,my old trick is to spray both sides of paper gaskets with copper coat,no matter what brand.
i sometimes spray only one side of valve cover gasket so i can reuse it once B)
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
06 May 2011 17:44
#449257
I've had some problems as of late with Cometic. You might want to ask someone who recently used their stuff. I bought a top end kit for one of my MX bikes, the head o-rings were not the right size diameter and the copper exhaust washer didn't even fit into the cylinder. I spoke to a few others with the same problems, so IDK if they are getting parts from different sources than what they used to.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • Nelson
06 May 2011 19:26
#449271
Maybe Vesrah is the way to go then.
What about the head gasket for 1075? I bet you guys can argue for hours about that :lol:
  • wireman
  • wireman's Avatar
06 May 2011 19:37
#449273
as long as you spray down both sides with copper coat you can make paper gaskets out of notebook paper! :woohoo:
buy a good 1 piece head gasket,pitch the center o-ring and fill the groove full of silicone let iy tack up really good before installing youll be fine B)
  • Nelson
06 May 2011 19:46
#449276
ah but what do you define as a "good 1 piece head gasket?" Brand? source? am I asking too much? :)
  • bountyhunter
  • bountyhunter's Avatar
06 May 2011 20:14
#449285
I had really bad results with Athena (gaskets disintegrated almost immediately on running). I'll never use them again.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
06 May 2011 20:42
#449294
Ive had good luck browsing Ebay for Kaw gaskets.
1975 Z1 900
2004 KX125
  • Nelson
06 May 2011 20:46
#449295
yes I've seen a bunch of stuff there. Just wanted to know about which ones are good.
  • DFIGPZ
  • DFIGPZ's Avatar
06 May 2011 20:53 - 06 May 2011 21:55
#449300
I use Genuine Kawasaki gaskets except for the head gasket then I
use the 1 pc cometic.
1984 750 Turbo
Last edit: 06 May 2011 21:55 by DFIGPZ.
  • DoubleDub
  • DoubleDub's Avatar
06 May 2011 22:03
#449320
You can get 1075 head gaskets from any of the piston manufacturers too. They include them in the piston "kits" and sell them individually.
