- Thank you received: 5
81 1000 CSR ,,
- Shoe48
- Live each day as it is your last
03 May 2006 17:59 #44903
by Shoe48
81 1000 CSR ,, was created by Shoe48
I posted some of this in chit chat But might be better here ,, I got my 1000 running today with lots of smoke , and back fires ,, It did clear up after a short while but was blowing gas back out of the carbs but then clearing up again ,, it was loseing Cyls. if I dropped the Idle down below 1,500 ,, I also did a compression test from left to right 120, 110, 90 120, this was done warm and the carbs open ,, anyway what would be my fist step ?? Run it a little long to see if a valve is sticking ? Or go ahead and check valve clearances ? I hope to get the stator problem fixed soon , I am on the look for a good used one .. Thanks For any help . Shoeman
- rammy
- Thank you received: 1
04 May 2006 06:12 #45001
by rammy
The barn yard;77 Kz650B-1 Kaw(the fun one) & 89 classic hog.
Chicago area-south burbs
Replied by rammy on topic 81 1000 CSR ,,
I would start with checking the valve clearance sounds like the intake side may be tight. Also check the cam timing if the intake cam is retarded (1 tooth)it will cause this to happen(pop through intake ) as the valves are not closed before compression stroke begins.Good luck
