APE kickstart block off plates? (another 6 spd tranny question for the 650)
- 77KZ650
03 May 2006 10:34
As previously discussed, the 550 6 spd tranny will swap into the 650 if the kick starter and its components are removed, then you use a 750 engine cover that didnt have the kick start (if you want to keep oil in the bike for more than a minute:P )
I was cruising around on KZZone and saw kickstart block of plates(part no=99211). would these work on the 650 as well as the larger bikes? if so, it could be a much easier part to get than a 750 non kickstart engine cover right?
thx
Scott
Post edited by: 77KZ650, at: 2006/05/03 13:36
thx
Scott
07 MDP Rookie of the Year
- wireman
Re: APE kickstart block off plates? (another 6 spd tranny question for the 650)
03 May 2006 10:42
how about just cutting one from a piece of 1/4" aluminum?
- 77KZ650
03 May 2006 13:23
wireman wrote:
Might try thathow about just cutting one from a piece of 1/4" aluminum?
- 77KZ650
03 May 2006 16:15
Was just out working on rear sets, and I had a good look at my engine cover while I was out there, I think the easiest way to block off the kick start "hole" would be to tap it (pipe thread) and put in a plug, theres a good inch of material that could be tapped, so it shouldnt be too hard to do.
If I get a 6 spd, this is the route Im going to try out, and Ill update then if it works outB)
- apeman
04 May 2006 13:53
Maybe you could thread the hole and mount a brass spigot in there. You could tell everyone that you carry some warm buttered rum in the engine housing.
Ok, lunchtime is over -- back to more serious activities!
Petaluma and Truckee, CA -- member since Jan. 23, 2003;
PREVIOUS KZs: 1980 KZ750H with 108,000 miles; 1980 KZ750E with 28,000 miles; and KZ750H street/cafe project, all sold a few years back.
This is what I do for fun, not for work. It is art, with a little engineering thrown in.
- RetroRiceRocketRider
04 May 2006 20:10
You could always just use the engine cover from a newer KZ650, like an '83 CSR650. They didn't have a kick starter, but IIRC used the same gasket and will fit.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- gas
04 May 2006 21:17
77KZ650 wrote:
Please include pics of the entire operation, transmission parts swap etc., if you can. It would be facinating. Thanks.
Was just out working on rear sets, and I had a good look at my engine cover while I was out there, I think the easiest way to block off the kick start "hole" would be to tap it (pipe thread) and put in a plug, theres a good inch of material that could be tapped, so it shouldnt be too hard to do.If I get a 6 spd, this is the route Im going to try out, and Ill update then if it works outB)
