starter clutch replacement
- striderx240
Re: starter clutch replacement
22 Apr 2011 14:34
My bad guys, I'm really sorry about all the confusion
Here are some pictures of my bike, hopefully someone can identify it correctly.
I'm currently still trying to remove the clutch casing and still no signs of budging.
[attachment:1]C:\fakepath\SAM_0697.JPG[/attachment]
- striderx240
22 Apr 2011 14:39
Sorry, it looks like the site is messing up.
- striderx240
- striderx240
- striderx240
- striderx240
22 Apr 2011 14:51Please Log in or Create an account to join the conversation.
- steell
22 Apr 2011 17:47 - 22 Apr 2011 17:54
Offhand, I'd say that is a 1983 (because you said so) KZ750N2 Spectre.
Shaft drive with fork boots indicate a Spectre, but I suppose it could be an 83 KZ750F1 LTD Shaft with fork boots added. The Spectre normally has gold colored wheels I think.
Have you removed the chrome starter cover that's on top of the cover you're trying to remove?
Starter clutch is inside the motor on a secondary shaft and can't be accessed from the side cover. You'll have to go through the oil pan to get there, but you still have to remove both side covers to slide the secondary shaft out, and I think the clutch assembly also.
Last edit: 22 Apr 2011 17:54 by steell.
- striderx240
22 Apr 2011 18:25
thanks for IDing the bike steell, yeah I removed the life side cover(not shown in picture) but I can't access the right side because the clutch cover won't come off, i unscrewed all cover screws, i sprayed wd40 on the outside, and got help from some friends to try to pull it off, is there something I'm missing? I think I'm going to have to take this to the shop
- striderx240
22 Apr 2011 22:03
okay finally, i got the clutch case off and clutch discs, now I'm trying to take off the centre bolt, the book tells me to use a special tool, is there any easy way around this or way of making the tool?
- KZQ
- Administrator
23 Apr 2011 11:31
I made mine with a piece of 1/4" steel and an acetylene torch.
Sorry about the poor focus but you get the idea.
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- striderx240
08 Jun 2011 23:59
Hey guys, so after months of putting off my repair project, I finally got back into it, I finally got the clutch hub off and I started to take off the secondary shaft and noticed that the nut that was holding the secondary shaft was loose already, could this be the cause of the bike not starting?
- KZQ
- Administrator
09 Jun 2011 00:31
Could be that it's an indication that the starter clutch has been worked on before, however I doubt that it's the root of your issues.
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
