Teflon Wrist Pin Buttons?
- z1kzonly
18 Apr 2011 17:30
I need 1, 17mm x .315 wrist pin button! I lost 1. For a 77mm J model engine
Called Paul Gast's shop (local) and they did not have any at the moment.
Parts guy said they are back to using metal clips.
Are these Teflon? or Nylon? nylotron?
I could make one if I had the stock.
Marty in Buffalo
Marty in Buffalo
- wireman
Re: Teflon Wrist Pin Buttons?
18 Apr 2011 17:32
i think theyre teflon
- mark1122
- Keep twisting it
18 Apr 2011 17:38wireman wrote: i think theyre teflon
that would be my guess too.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Injected
18 Apr 2011 23:16
They are teflon... you can buy it by the inch at any good plastics place, usually spec'd in inch diameters... you can make one in a lathe in about 5 minutes.
I have homemade ones in my drag bike... no issues.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
- z1kzonly
19 Apr 2011 00:17
Thanks, that's what I thought.
Marty
Marty
- Jack
19 Apr 2011 10:05
Marty,as posted you can make your own. I have a couple of 17mm. buttons that are .350 thick, easily shaved down to fit if you want them - let me know if interested and I'll pop them in mail. BTW, I hate circlips even if some people have changed back to them - nothing like crawling around the shop floor searching for a clip that got away.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- Kidkawie
- I bleed premix
19 Apr 2011 10:18 - 19 Apr 2011 10:18
If you want to make your own, I just bought some UHMW Polyethylene rod from McMaster Carr for $6.70. Used about an inch of it for a shock lowering spacer. They should have teflon too.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
Last edit: 19 Apr 2011 10:18 by Kidkawie.
