need 1075 engine rebuild 101
  • glory roader
  • glory roader's Avatar Topic Author
16 Apr 2011 17:48
#444989
What cam specs, port, ect...is best for 1075cc upgrade. I need a good foundation and the best carbs. Currently I have 29 smoothbores. But I heard with a 1075cc and the right cams and rs34 carbs I could do some good damage.
  • hocbj23
  • hocbj23's Avatar
Re: need 1075 engine rebuild 101
16 Apr 2011 17:50
#444990
To what?ur pocketbook for sure.
  • glory roader
16 Apr 2011 18:07
#444992
I hear you! But she's my baby
  • hocbj23
  • hocbj23's Avatar
16 Apr 2011 18:21
#444993
I understand--I have 3 sitting in my shop.But realistically there are all kinds of 600cc crotch rockets out there that will out perform our babies.U just need to come up with a combo that meets ur daily riding needs and let it go at that.1075 plus a set of nice street cams (Webb et al),plus the round slides should do a good job.If u want a little more,let Larry Cavanaugh(Cavanaugh Racing)street port ur heads and do a good valve job and u should be tight.I asume u have already done a good aftermarket ignition swap like Dyna S or Dyna 2000?bj
  • wireman
  • wireman's Avatar
16 Apr 2011 18:52
#445004
hocbj23 wrote: I understand--I have 3 sitting in my shop.But realistically there are all kinds of 600cc crotch rockets out there that will out perform our babies.U just need to come up with a combo that meets ur daily riding needs and let it go at that.1075 plus a set of nice street cams (Webb et al),plus the round slides should do a good job.If u want a little more,let Larry Cavanaugh(Cavanaugh Racing)street port ur heads and do a good valve job and u should be tight.I asume u have already done a good aftermarket ignition swap like Dyna S or Dyna 2000?bj
what bj said! B)
  • testarossa
  • testarossa's Avatar
16 Apr 2011 19:03
#445008
Larry did say that in order to see the benefits of the RS34's you need port work.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • TexasKZ
  • TexasKZ's Avatar
16 Apr 2011 20:42
#445024
  • wireman
  • wireman's Avatar
17 Apr 2011 00:45
#445063
TexasKZ wrote: Check this out
flowbenchtech.com/porting/CRH/
i cant check it out,always ends up costing me money! :woohoo:
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
18 Apr 2011 17:58
#445369
start with the 1075 and the 29's .see how u like it. the cam carb choice will depend on where u want the power. if u keep everything on the small side ,29's,under.400 lift cams, small intake runners. u will have nice low end power but will suffer up top. if u feel the need for more up top then u need to spend some more money. get Larry to port the head, and at that time Larry can help u pick a carb , and bigger carbs, if u feel u need even more top end. but be warned , as u go searching for more top end the bottom will get softer.
Good luck
M
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Stu Pidasole
  • Stu Pidasole's Avatar
  • if you aint mod'n, you aint rock'n!
18 Apr 2011 18:30
#445375
go see larry. i too will be running the rs 34 flats.
  • DoubleDub
  • DoubleDub's Avatar
18 Apr 2011 19:17
#445381
mark1122 wrote: start with the 1075 and the 29's .see how u like it. the cam carb choice will depend on where u want the power. if u keep everything on the small side ,29's,under.400 lift cams, small intake runners. u will have nice low end power but will suffer up top. if u feel the need for more up top then u need to spend some more money. get Larry to port the head, and at that time Larry can help u pick a carb , and bigger carbs, if u feel u need even more top end. but be warned , as u go searching for more top end the bottom will get softer.
Good luck
M
Well stated!
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
18 Apr 2011 22:47
#445417
I have a 1075 engine and ran it with 29's,Andrews 3X cams (418 lift), and stock head. Great combo.It could have been better but it is good enough.
I have a head that i spent hours on to smooth out the rough spots but won't install it until the engine needs tearing down.
I've had that engine for 12 years and suspect it will be a few more years before the engine needs anything.
Roy
