Brake Rotor Resurfacing
  • dshelly
  • dshelly's Avatar Topic Author
16 Apr 2011 14:17
#444958
Anyone know where I can get a set of brake rotors resurfaced?
, dshelly
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
  • TexasKZ
  • TexasKZ's Avatar
Re: Brake Rotor Resurfacing
16 Apr 2011 14:19
#444959
A shop that resurfaces automotive flywheels should be able to do the job.
  • dshelly
16 Apr 2011 14:22
#444960
I did think of that but, most flywheels arn't stainless. Figured it would take a different type of wheel and if they are not set up to do that .......
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
  • TomW
  • TomW's Avatar
  • Keep the blue side up.
16 Apr 2011 14:42
#444964
What? 25 years as a machinist and you don't have a lathe in your basement?
If the rotors aren't scored too deeply try one of these, www.enginehones.com/rotorhone.html
If they are real bad they'll need to be cut, preferably on both sides simultaneously so the sides are dead nuts parallel. DAMHIKT! A brake rotor lathe is the machine tool of choice. Try an automotive brake shop. You may have to make an adapter for the lathes arbor. I can hone them here if you're close to West Bend WI or want to ship them.
'78 KZ1000B2 LTD stock + Vetter Fairing & luggage
'91 ZG1200B5 Voyager XII, stock
  • retterath
  • retterath's Avatar
16 Apr 2011 14:43
#444965
Why does it need to be resurfaced?
16 Apr 2011 15:01
#444968
Stainless motorcycle rotors should be precision ground instead of being turned on a brake lathe like car rotors. see links for additional info:
www.vintagemotorcyclesonline.com/service.../disc-brake-grinding
forums.kz650.info/index.php?topic=5026.0
  • bountyhunter
  • bountyhunter's Avatar
16 Apr 2011 15:44
#444973
They do have to be ground, not turned on a lathe. If they are not warped and only have minor grooves, they don't have to be surfaced. However, I did mine myself to get them smoothed out after a lot of wear. I bought some new rectangular sharpening stones and used oil to face them by hand. Just set the rotors in your lap and do it watching TV, it takes a long time. Keep turning and working the faces and it will smooth out. It will only take off a very slight amount of material, it mostly grinds down the high tops of the ridges.
  • dshelly
16 Apr 2011 15:58
#444976
Yea, Iv'e been doing machine work for a long time. But, I don't have a flywheel grinder or a brake lathe for that matter. I remember seeing the ad on ebay for having them resurfaced but the guy isn't listing it now . The resurface disc looks interesting, anyone ever used one?
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
  • wireman
  • wireman's Avatar
16 Apr 2011 18:56
#445005
check your pms
