Head Gasket
- Frampty
Head Gasket
08 Apr 2011 16:29
Hi there
(SR)Z650-D2 1979 bought from ebay last year,imported to the UK from USA about the middle nineties.
Am having a few problems ,the bike is very difficult to start. Bought some new spark plugs ,condenser and points and had the timing checked,still difficult to start.
Last weekend managed to get it to start and went out for a 50mile ride,when I returned home there was oil all over my boots.looks like the head gasket is leaking.
Is it possible to change the Head Gasket while the engine is in situ?
Just would like to get a few days when I can get out and ride
- wireman
Re: Head Gasket
08 Apr 2011 16:57
clean motor up first and make sure its not a valve cover leaking.
have you checked valve clearances and had carbs cleaned?
- Mcdroid
- Gone Kwackers
Re: Head Gasket
08 Apr 2011 17:05wireman wrote: clean motor up first and make sure its not a valve cover leaking.
+1 on the wireman
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- MFolks
Re: Head Gasket
08 Apr 2011 17:35
The spray on foot powder will quickly show where the leak is, it's water removable. Just make sure the engine is degreased well to remove any oil residue before spraying with the foot powder.
- mark1122
- Keep twisting it
Re: Head Gasket
08 Apr 2011 17:59
u should do a compression test while u are at it. u could have poor compression causing a hard stat issue, or blow-by causing oil leaks.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Kraz1
Re: Head Gasket
08 Apr 2011 19:21Please Log in or Create an account to join the conversation.
