leaky valve stem
  • ace
  • ace's Avatar Topic Author
  • 78kz1000
leaky valve stem
06 Apr 2011 15:51
#443013
any quick fixes for leaky stem ?? must one pull the tire? i have tubeless lester mags .. if i need a new one where would i find it?? btw its only a slow leak....thanx ace.
78kz1000
  • wireman
  • wireman's Avatar
Re: leaky valve stem
06 Apr 2011 16:05
#443014
is it the stem or the valve core? B)
  • ace
  • 78kz1000
06 Apr 2011 16:08
#443016
core i believe
78kz1000
  • wireman
  • wireman's Avatar
06 Apr 2011 16:10
#443017
if its just the valve core you can try to tighten it or just replace it,any gas station that fixes tires should have a valve core they can throw in there for ya B)
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
06 Apr 2011 16:35
#443019
wireman wrote: if its just the valve core you can try to tighten it or just replace it,any gas station that fixes tires should have a valve core they can throw in there for ya B)
Yes, try the easy fix first...if you don't have an old-fashioned flat-fixin' filling station around, then O'Reilly's, Tractor Supply, etc. sells valve stem cores and the removal tool.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
06 Apr 2011 16:53 - 07 Apr 2011 22:53
#443022
ace wrote: any quick fixes for leaky stem ?? must one pull the tire? i have tubeless lester mags .. if i need a new one where would i find it?? btw its only a slow leak....thanx ace.
Might be a valve core issue, such as some crud inside the core.
Could loosen and retighten the core, or remove and clean it with compressed air.
If needed, a tire repair shop may have a replacement core.
If the stem itself is damaged, a tire repair shop should have the correct size replacement stem.
A larger concern imo is whether or not the wheels are in fact intended for tubeless tire.
Imo should run a tubeless tire ONLY on a tubeless style rim, which has the ridges inside, and is often marked "tubeless."
Some folks have gotten away with using tubeless tires on tube style mags without using tubes. I wish them well and hope Lady Luck continues smiling upon them. And that they don't hit a good bump while leaned over hard in a corner.
Opting for safety, am running tubes in my Lesters.
Attachment tubevtubelessrimtxt.JPG not found
Good Fortune! :)
Last edit: 07 Apr 2011 22:53 by Patton.
  • gane
  • gane's Avatar
07 Apr 2011 22:31
#443338
Patton,Your' pic is the best "definative" contrast between "tube type" & tubeless I've seen. If only there was some way to make it a "must view" for the many neophites who legitimatly need to understand the WHY they need to run tubes (especially w/mag type wheels) Thanks G
[img][/img] 1977 KZ1000A1
