- Thank you received: 6
is there adifference between gpz cams and j-head cams?
- kawsakiman
01 May 2006 16:16 #44239
by kawsakiman
is there adifference between gpz cams and j-head cams? was created by kawsakiman
i have a chance to buy my buddies gpz1100 and i need to know if the cams will work in my 91 j-head.the bike is pretty trashed so a rebuild is out.it's strictly a parts bike now.the gpz is an 82.he says it has aftermarket cams but i cannot pull it apart to inspect it thanks guys!until i buy it or at least get a new cam cover gasket and i don't want to waste my time if i know it won't work.
Post edited by: kawsakiman, at: 2006/05/01 19:20
- craigpuckett
01 May 2006 16:58 #44254
by craigpuckett
Replied by craigpuckett on topic is there adifference between gpz cams and j-head cams?
the gpz1100 cams will interchange with the 1000J cams,if the gpz has aftermarket cams they will have 3 bolts w/adaptor sprockets.
- wireman
- Visitor
01 May 2006 17:11 #44260
by wireman
Replied by wireman on topic is there adifference between gpz cams and j-head cams?
want to sell the gpz head?:whistle:
