assembly of clutch actuator and pushrod
  • 2wheeladdict
  • 2wheeladdict's Avatar Topic Author
02 Apr 2011 00:46
#442100
Hello, assembling another sprocket cover(to replace a broken one) on my 80 kz1000 Ltd. this was apart when i bought the bike so I have a question about assembly order, I can't tell from the parts diagram. There is a 3/8 steel ball located somewhere in the mix does it go between the pushrod and the actuator on the sprocket cover or is it internal inside the exterior shift linkage cover? any help would be appreciated.
80 KZ1000 LTD
81 Yamaha XJ650 maxim
84 CR60r
Re: assembly of clutch actuator and pushrod
02 Apr 2011 00:56
#442102
Ball bearing #9 goes inside the tunnel before inserting the pushrod into the tunnel.
Good Fortune! :)
  • MFolks
  • MFolks's Avatar
02 Apr 2011 01:02
#442104
Or order a Ape race Parts KCB900 needle bearing clutch pusher.
  • 2wheeladdict
02 Apr 2011 08:06
#442118
The manual says to remove the pushrod from the case when disassembling. should the pushrod just pull out of the tunnel? mine has about 1/4 inch end play but will not pull out. I have not tried to use much force pulling on it. I do not see any clips or retainers on the parts diagram. Thanks.
80 KZ1000 LTD
84 CR60r
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
02 Apr 2011 08:11
#442119
Yeah it just pulls right out. Mine was a little gummed up but it came out easy enough. When you get it out make sure it's not bent.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
  • APE Jay
  • APE Jay's Avatar
02 Apr 2011 14:07 - 02 Apr 2011 14:07
#442175
MFolks wrote: Or order a Ape race Parts KCB900 needle bearing clutch pusher.
Now that's a great idea.:P
Last edit: 02 Apr 2011 14:07 by APE Jay.
02 Apr 2011 14:19
#442178
This replaces Part No. 10 as shown in the exploded view.
Will continue using the push rod and ball bearing.
Good Fortune! :)
  • P21
  • P21's Avatar
02 Apr 2011 14:38
#442180
you da man Patton its great to have you on the forum.
just a pat on the back my friend
Kawasaki KZ 1000 Police (2002) P21
  • Kraz1
  • Kraz1's Avatar
02 Apr 2011 14:42 - 02 Apr 2011 14:43
#442181
Agreed... Having had a Clutch Actuator Lock-up/Seize while riding, it gave me a complete understanding of the benefit of this part. :laugh:
Last edit: 02 Apr 2011 14:43 by Kraz1.
  • 2wheeladdict
02 Apr 2011 15:31
#442190
I think this may be what happend to my bike. Trying to piece together the issues the bike may have. Cracked sprocket cover, repaired (welded) clutch actuator mechanism. they actually had the hole where the pushrod goes into the actuator filled with weld, and the pushrod tight in the case. I believe I will be pulling the clutch and inspecting the innards in the near future.
80 KZ1000 LTD
84 CR60r
