kz750 L3/GPz sloted camshaft sprokets
  • mbsween
  • mbsween's Avatar Topic Author
30 Apr 2006 21:30
#44067
I'm putting a new cam chain in the kz. had the head decked .0020 when I had the 810 kit done. I believe I need to adjust the cam timing tdue to that mod, but I can't seem to find slotted sprockets for the 750 anywhere.
I've seen the GPz 1100 (2 bolt style), but I have no clue if they fit the 750
Anyone know where to get these?
  • 77KZ650
  • 77KZ650's Avatar
Re: kz750 L3/GPz sloted camshaft sprokets
30 Apr 2006 21:42
#44068
cant you slot them yourself?
07 MDP Rookie of the Year
  • wireman
  • wireman's Avatar
30 Apr 2006 22:01
#44070
get yourself a couple rat tail and chainsaw files,go slow.:whistle:
  • steell
  • steell's Avatar
30 Apr 2006 22:39
#44084
A Dremel would work a lot better, the bolt heads sit in a recess in the sprocket, and you will probably have to enlarge the recess to allow the bolts to sit flush.
It don't take much, .010" will probably work, but I'd go .020" just to make sure.
You can get carbide cutters for the Dremel, and a chainsaw sharpening stone for the Dremel works well also. I burnt up a HSS cutter on the Dremel after doing almost one sprocket :)
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
01 May 2006 02:37
#44102
I wouldn't bother for 2 thou off the head...it's nothing.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
  • steell
  • steell's Avatar
01 May 2006 10:32
#44173
You're right, I read it as .020, I missed trhe extra 0 making it .0020 :D
  • APE Jay
  • APE Jay's Avatar
01 May 2006 12:54
#44202
We make the GPZ 2 bolt, but they won't fit the 750.
Jay
  • mbsween
02 May 2006 09:35
#44465
Whoops,
I meant .020 was decked. Thats What I get for staying up late. I have the dremel and the bits, so taht shouldn't be an issue.
Do you use red loctite or anything like that once they're dialed in?
Thanks for the input
matt
  • steell
  • steell's Avatar
02 May 2006 11:07
#44496
Red LocTight is a very good idea, once you have the cams dialed in. After you are sure the cam timing is spot on, then take out one bolt at a time and apply the LocTight, you really don't want to have to remove the bolts after applying the red stuff! :D
  • mbsween
06 May 2006 08:19
#45476
Okay I have everything ready to go to repalce the cam chain.
Except I can't figure out the breaking end from the riveting end. You can tell I do this often right? The Tool I bought is from Z1 enterprises (K&L35-7256)
www.z1enterprises.com/detail.aspx?ID=1693
Can anyone provide some insight as to which side does what?
Thanks
Matt
