650 engine upgrades
  • ratmeister
  • ratmeister's Avatar Topic Author
650 engine upgrades
30 Apr 2006 18:01
#43999
Hi all, I have searched the archives and found alot of information on the many enhancments that can be performed on the 650 engine. My question is what is the best bang for the buck to increase power without totally rebuilding the engine (I am not a skilled mechanic)?
I just got a 1977 kz650 c1 parts bike and plan on learning as I go on my first complete dissassembly. I am planning on going with a modern mono-shock rear and a newer front end, and just want a bit more than stock. While I have it appart what can I do that is inexpensive, but will give me a bit more oomph?
Thanks in advance, and as soon as the rain stops, I will post a few before pics...
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: 650 engine upgrades
30 Apr 2006 18:30
#44008
A little bit of porting in the right places can add some oomph. I had mine done years ago at a shop. They did it on there own during a rebuild. Try to find out the proper areas to shave, it may be something you can do yourself.
If I'm not mistaken, where the rubber boots from the carbs connect to the cylinder head, there's a bit of an edge in the metal that can be removed and smoothed. And then also around the valve guide area. But again, you really need to know where and how much.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
  • reborn650
  • reborn650's Avatar
30 Apr 2006 19:47
#44030
Having gone through this twice with my '77 650 in the last 14 months, here's my 2 cents worth. If the bike is still running strong and compression is good leave the guts alone.
Check the valves for clearance and lap them if needed. Soak and clean out the carbs, port the head taking out just enough to give good smooth airflow (remove the casting edges using a variable speed drill and aluminum cutting bit,) hook up the coil wiring modification (from wiredgeorge in the tech section) and throw an inexpensive header pipe on the bike. With the pipe you will have to rejet and kzr members will give you lots of advice for recommended jetting sizes.
The above listed massaging wilth a check of the ignition should help wake up the bike and it will cost you probably ony $350-$500
Cheers-Colin Firth -Ontario Canada
Here's a pic of what the 650 looked like last season...coming soon...
'77 Kz 650 Custom - (Miss July on 2006 Kzr Calendar,) Newest rebuild includes Wiseco 810 kit, Kz750 cams, Kz750 intake valves, 750 GPz springs, Ported head, WG Mikuni 28's, Velocity Stacks, Dyna Ignition and coils, MAC pipe, 14 tooth front sprocket, going back to original '77 Moon Dust Silver. Goal is to have a stock-looking bike that will tighten up any loose dental fillings off the light.
-1998 Jeep TJ Wrangler 4.0...
  • 77KZ650
  • 77KZ650's Avatar
30 Apr 2006 20:05
#44043
Another thing to consider, might be getting a 750 block and pistons if you can get them cheap, might be a bit rare tho. if they are in good shape it would be a good displacement bump without any costly oversize piston kits. and if you ever do plan on going over sized in the future, the 810 kit would be another jump in power
07 MDP Rookie of the Year
  • 77KZ650
  • 77KZ650's Avatar
30 Apr 2006 20:15
#44049
you wouldnt happen to have any pics of your head after this work would you?
  • steell
  • steell's Avatar
30 Apr 2006 21:02
#44063
You can also look for a KZ750 motor (generally $250-$350) and bolt in an additional 10-11 hp with the capacity for more.
It depends on what you want to do :)
  • wireman
  • wireman's Avatar
30 Apr 2006 21:59
#44069
if the motor is tired or you have a spare you just want to freshen up a good stock rebuild and blueprinting can make quite a differance.these motors are built on a production line,no two ever turn out exactly the same.if you can get away with stock bore with just rings and spend a little money on a good valve job and clean up ports ,just straighten up the rough spots dont try and hog the ports out youll do more damage than good.good springs and a good set of drop in cams.a set of 26s a decent header and an electronic ignition and you should a have a pretty reliable good running little bike that should keep you entertained till you grow into something bigger.;) goodluck,happy wrenching!
  • mariozappa
  • mariozappa's Avatar
01 May 2006 05:14
#44115
...and a good set of drop in cams...
What would be a good set of drop in cams for a 650?
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • N0NB
  • N0NB's Avatar
  • Blue handles better
01 May 2006 05:31
#44117
Shouldn't it be badged a 750 then? :unsure: Better get new sidecover emblems :P
Has anyone done real world dyno testing when installing headers and such on these bikes? I know the advertising claims, but I am truly curious whether gains are made in the real world or if the powerband is just adjusted.
- Nate >>
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
  • 77KZ650
  • 77KZ650's Avatar
01 May 2006 13:30
#44210
KZ750 cams are a bit hotter, gpz 750 cams are hotter still (although you dont have the worm gear to drive the tach, so then you need to get an electronic tach) and if you want to $pend a lot, get a set of web cams as they are even better
  • 77KZ650
  • 77KZ650's Avatar
01 May 2006 16:10
#44238
If you do the whole motor swap for a 750, you might as well get the gpz 750 for a bit more "oomph";)
