How do you fix broken fins on cylinder?
  • Nelson
  • Nelson's Avatar Topic Author
21 Mar 2011 02:06
#439343
No I didn't break any...:P
I sometimes see good used deals on performance piston kits with a matching cylinder, but it has a broken fin so noone buys it or it sells cheap. I might buy one of these if the repair is simple/cheap enough to do. The engine has to look right, I don't want busted stuff on it!
I don't weld aluminum, but I'm guessing a pro could easily weld on a piece of plate and then shape it to match. Actually I could do a nice job of the shaping myself, but I can't do the welding.
Does this sound like something that would be easy for a pro welder to do? Is there anything I'm overlooking?
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
  • wireman
  • wireman's Avatar
Re: How do you fix broken fins on cylinder?
21 Mar 2011 02:47
#439347
pretty much sums it up!
some guys buy junk cylinder heads just to use them for pieces to fix fins on good cylinder heads. B)
  • tinlizzie37
  • tinlizzie37's Avatar
21 Mar 2011 11:38
#439403
Hi Nelson, I know it can be done. I repaired the cylinder fins on a H2 Kaw engine the was in a wreck .Not only the fins, but all the motor mount castings were broken off, and it had a large hole in the transmission. All turned out great. Bob
Bob KZ 650 E1, En 450
  • stonemaster
  • stonemaster's Avatar
21 Mar 2011 11:45 - 21 Mar 2011 11:46
#439405
Nelson wrote: No I didn't break any...:P
thats how one of mine was repaired on another bike, dude shaped a piece of aluminum and tig welded it
Last edit: 21 Mar 2011 11:46 by stonemaster.
  • kawman14733
  • kawman14733's Avatar
21 Mar 2011 14:36
#439430
if you can braze with a torch , build it up with aluminum rod and grind it /file to shape...
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
21 Mar 2011 16:11
#439444
if it is going to be painted i have seen them tape cardboard under the fin and pile jb weld on let it dry and shape it.
we have a 1953 indian chief 80" engine that had broken fins on the aluminum flat head.the welder sat down and ran little beads down each fin until they were built up enough.then metal finished them back and you can not tell they were ever broken.
  • larrycavan
  • larrycavan's Avatar
21 Mar 2011 18:31 - 21 Mar 2011 18:33
#439481
Cylinder fins are small. That being the case you might consider getting one of those aluminum welding kits that use a torch. You would simply build up the broken area and grind it to shape. Kit's are not that expensive and will work for at least cosmetic repairs like that.
I tried those rods once on a broken pressure washer and the weld would not hold. After speaking to a pro welder I was informed that while it's not advertised, the rod has a shelf life. The rod I used was pretty old.
www.alumiweld.com/
Larry C
Last edit: 21 Mar 2011 18:33 by larrycavan.
  • stonemaster
21 Mar 2011 18:52
#439496
www.alumiweld.com/
Larry C
+1 on the shelf life, i know some guys that keep rods in the refrigerator to increase their life
  • Nelson
21 Mar 2011 22:08
#439565
cool, lots of ideas. I thought of the JB weld plan also, but it seems pretty redneck.. even for me.:laugh:
  • APE Jay
  • APE Jay's Avatar
22 Mar 2011 00:39
#439610
Jim the welder at A1 Weldors in No.Hollywood is a genius. He does all of our fin repair. None better.
  • wireman
  • wireman's Avatar
22 Mar 2011 01:21
#439619
Ztorch is actually the best in this part of the globe B)
