shift fork interchangeability?
  • jordan
  • jordan's Avatar Topic Author
14 Mar 2011 06:45
#437874
I am all ready to put my bottom end together for my 1428 kz1000 motor but I realized I am missing the shift shaft and both forks on it! I looked at schnitz, ape, and other places and its quite a bit to replace new. Found some used for 75 and bidding on some now but will most likely get outbid. Do any other kz's other than the 900 have the same forks? J's maybe?
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold :(
1972 Kawasaki s2 350-parted on ebay :(
1973 Kawasaki s2 350-parted on ebay :(
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
  • TexasKZ
  • TexasKZ's Avatar
Re: shift fork interchangeability?
14 Mar 2011 13:22 - 14 Mar 2011 13:26
#437942
You can check interchangeability on Kawasaki's website.
It looks like all 900s and 1000s prior to 1981 use the same parts.
Last edit: 14 Mar 2011 13:26 by TexasKZ.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
14 Mar 2011 13:37
#437945
jordan,
are you talking about the shift shaft and the forks that are on it under the countershaft cover?
the claw that turns the drum?
or the actual shift forks that slide the gears?
  • z1kzonly
  • z1kzonly's Avatar
14 Mar 2011 15:22
#437965
Hi Jordan, I sent you PM.
Need a refresher course on shift forks.
Are the 2 identical?
I know the big one is on the drum.
These 2 have a T1 and the other has a T2 on it
They are the same and not bent.
  • racer54
  • racer54's Avatar
14 Mar 2011 16:17
#437971
Not sure about using the T1 and T2 forks in another position. I think there is a T6 also. I do know you can't use a J-model fork or any part of that trans. with a KZ trans. Otherwise, all the trans. parts for a Z1/KZ900/kz1000 from 1973-1980 will interchange. I believe some of the 1981 models were also of the KZ motor and not the J model.
  • jordan
14 Mar 2011 19:05
#438014
yes z1kzonly, that is exactly what im looking for. PM me with what you want for them. Once again thanks alot!
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
  • z1kzonly
  • z1kzonly's Avatar
14 Mar 2011 19:56
#438022
Hi all, here is another picture of the end of shaft. The shaft is solid and has that little clip with a roller on it.
The Z1-KZ 900 manual and items on ebay don't have that piece on the end. Might from a 78-79 KZ1000
Maybe someone can verify this end of shaft.
Thanks
  • TomW
  • TomW's Avatar
  • Keep the blue side up.
15 Mar 2011 02:20
#438083
Thanks
I can verify that my late 78 KZ1000 LTD does NOT have the plate with a roller on the end. The two forks are identical according to the FSM.
'78 KZ1000B2 LTD stock + Vetter Fairing & luggage
'91 ZG1200B5 Voyager XII, stock
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
15 Mar 2011 02:43
#438085
Thanks
Correct...the shift forks are the same for the Z1/KZ900/KZ1000 (early) line while there is a difference between late and early KZ1000 shift shaft.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
