first time engine teardown
- murr50
13 Mar 2011 09:43
So I was intending on replacing the valve cover, cylinder head, and barrel gaskets of my 77 kz650 over the weekend, but unfortunately some dirt fell into the crank case from the cylinder studs when i was lifting the barrels off. It seems to me that I have just signed up to do a complete engine tear down, and split the cases. I was wondering what the easiest way to go about this is. Since I am only interested in getting the dirt cleaned out of there, can i simply take off the sump and unbolt the cases and lift everything out? The clutch and rotor are still attached to the engine, do I need to remove them?
I could use a push in the right direction, any help would be greatly appreciated, thanks.
1977 kz650 C
- Mcdroid
- Gone Kwackers
Re: first time engine teardown
13 Mar 2011 11:20 - 13 Mar 2011 11:23
From your description it appears that you do not own a genuine Kawasaki shop manual. In that manual, is a detailed set of instructions and procedures for rebuilding a motor. Step one would be to obtain the shop manual, if you don't already own one.
However, if it is just soft dirt/paper gasket material you dropped into the crankcase, you can probably get by by just dropping the pan.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 13 Mar 2011 11:23 by Mcdroid.
- larrycavan
13 Mar 2011 11:34
murr50 wrote:
You don't have to tear the motor completely apart.
Pull the oil pan and use some kerosene to wash out the bottom end. Just do a thorough job, use common sense and you'll be fine.
If you do decide to tear the engine down for whatever reason. Get a service manual and read it.
If you split the cases, take 10 extra minutes before you do anything and make a cardboard pattern for the bolt locations. Poke some small holes in the pattern and use to hold the bolts you remove.
Little things like that save you grief and time when you go to assemble the engine later.
Larry C
Larry C
- stonemaster
13 Mar 2011 11:38
set the motor up on a bench, drain oil, remove oil filter, go buy 5 gallons of kerosene and one of those sqeeze pump siphons, remove side covers and leave oil drain plug out, pump kerosene through the block, unless u just want to tear it apart
- stonemaster
- murr50
13 Mar 2011 14:13
excellent guys, thanks for the help. This will definitely save me a ton of time and grief.
1977 kz650 C
- wireman
13 Mar 2011 14:17
larrycavan wrote:
what he said!murr50 wrote:So I was intending on replacing the valve cover, cylinder head, and barrel gaskets of my 77 kz650 over the weekend, but unfortunately some dirt fell into the crank case from the cylinder studs when i was lifting the barrels off. It seems to me that I have just signed up to do a complete engine tear down, and split the cases. I was wondering what the easiest way to go about this is. Since I am only interested in getting the dirt cleaned out of there, can i simply take off the sump and unbolt the cases and lift everything out? The clutch and rotor are still attached to the engine, do I need to remove them?
Larry C
