kz750 engine rebuild/check
  • pugeyed
  • pugeyed's Avatar Topic Author
13 Mar 2011 01:14
#437581
hi folks now my kz750 h3 project is stripped down to bare essentials i thought i would take a look at the engine.
wipped the sump off and cleaned all that out and managed to get 7 of the 8 exhaust studs out (last one snapped flush with the head):unsure:
got the bore scope from work and put it down the spark plug hole to see how dirty it is in there, its not too bad but i have no idea of the mileage of the engine so thought i would take the head off for a clean/check/skim on valves etc (plus get the broken studs sorted)
question is should i check valve clearances before i take the head off ?:S
im good with me hands but dont have vast amount of engine experience and dont have access to a manual?
(ps the engine is strange because it seems to me like its never been apart):S
Many thanks for any help/suggestions you may have.
Mark.:)
kz750 h3 1982 4cl
Re: kz750 engine rebuild/check
13 Mar 2011 03:13 - 13 Mar 2011 03:15
#437582
pugeyed wrote:
...kz750 h3...dont have access to a manual....
Here's a link to site with manual.
Then scroll down and click on The Bible...
Click > kz.mbsween.com/
Good Fortune! :)
Last edit: 13 Mar 2011 03:15 by Patton.
  • pugeyed
13 Mar 2011 03:16 - 13 Mar 2011 03:19
#437583
thats great!
thanks for that it will be much easier if i know what im doing?
bit worried about splitting the cam chain and timing it all up afterwards :unsure:
kz750 h3 1982 4cl
Last edit: 13 Mar 2011 03:19 by pugeyed.
  • turboguzzi
  • turboguzzi's Avatar
13 Mar 2011 03:32
#437584
pugeyed wrote:
thats great!
unless the engine has some crazy mileage, cant see why you'd split the chain. it can be disassembled without splitting the chain.
retiming is no big deal on these, just follow the instructions in the manual.
that said, maybe tell us what are you trying to achieve by "taking a look at the engine" and we might give you more focused advice.
For instance, not so clear as why you removed all the ex studs (breaking one too) either....
TG
  • pugeyed
13 Mar 2011 03:45 - 13 Mar 2011 03:52
#437587
well since im rebuilding the whole bike i thought it would be a good idea to see if the engine is in a fit state.
the previous owner had it turning over but he said it wouldent fire (might be because the float bowls were full of crap! :laugh: )
its good news that i wont have to split the cam chain.
had to remove the exhaust studs as they were well past there best and were more rust than metal
ideally i want to whip the head off to clean the top of the pistons, get the exhaust stud repaired/removed and then they can skim the head and check valves/seats
bottom end doesnt seem to be too bad , dont think its high mileage might have done 10k.
also want to check the clutch see if any plates need replacing
then i can either do the lemon juice trick on the carbs or send them off for ultrasonic cleaning
cheers for all your help!
Edit:
do you think i should do the clearances before i take the head off, no known service history at all with the bike, dont want it to go bang
kz750 h3 1982 4cl
Last edit: 13 Mar 2011 03:52 by pugeyed.
  • turboguzzi
13 Mar 2011 04:04
#437588
you do your valve clearance (guess your talking about shims) as the last stage of assembly, AFTER all head work was done. clearances will change if any of the valves is changed or seats needs grinding/lapping.
  • pugeyed
13 Mar 2011 04:28
#437590
ah ok yes the clearances would change if you had and valve work done.
many thanks for all your help
Mark.
kz750 h3 1982 4cl
  • wireman
  • wireman's Avatar
13 Mar 2011 05:34
#437597
id check valve clearances and run a compression test or leak down test if possible before tearing motor down to get an idea of motor condition. B)
  • pugeyed
13 Mar 2011 05:50
#437602
how do you do a leak down test matey?
i can check clearances before thats not a problem
kz750 h3 1982 4cl
  • wireman
  • wireman's Avatar
13 Mar 2011 06:18
#437611
they make a tool for it,i wonder if one can be rented from auto parts store?
then you pump some air in from a compressor and listen for leaks. B)
  • pugeyed
13 Mar 2011 08:57
#437649
ok may be simple for some on here but am struggling with valve clearances
i alligned the 1 4 T mark then it says to check 1 and 3 or 2 and 4 on the inlet side,
then it says turn the crankshaft half a turn and align with
2 3 T mark, (i dont have one of these , not that i can see anyway):S
kz750 h3 1982 4cl
  • DoubleDub
  • DoubleDub's Avatar
13 Mar 2011 09:16
#437658
Can you upload a photo of your timing marks that do exist? I'm sure others would be able to help.
