Cleaning/polishing cases--what did you use?
- SPARKY47
- 1980 KZ500 B2
Re: Cleaning/polishing cases--what did you use?
01 Apr 2011 10:30Kapahulu wrote:How do you get in between the fins and into the other hard to reach places? This Nuvite polish looks fantastic.650ed wrote: Take a look at the Nuvite site below. Nuvite offers several grades of metal (aluminum) polish from coarse to very fine so you can get a quick cut on corroded metal and then move to a finer grade. It’s used on airplanes, and the finest compound leaves a nice shine.
Nuvite
For finishing work I also recommend S100 finish restorer paste or X-treem polish wading. Both of these leave a very fine finished shine.
S100
X-treem
Get a piece of clean rope with a diameter which offers just a little resistance to being "sawed" back and forth between the fins then soak in polish of choice.
1980 KZ500 B2
- wireman
01 Apr 2011 10:35
sand paper rapped around a paint stick works between fins on head,sand paper around a pencil works good between cylinder fins.
files and a block sander work good on fins and flat areas
- Kidkawie
- I bleed premix
01 Apr 2011 10:48
You can put a soda blaster together for under $10 and buy 3 large boxes of baking soda for $3 each. I wish I had my soda blaster when I put my 900 together, but I use it constantly on my other projects. I originally did my 900 by hand, the other week I sealed up the intake, took it outside and blasted away. Obviously had to wash all the soda off after, but it came out pretty good!
My homemade blaster. The hose goes in the box of soda, then attach the gun to my air compressor.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- Proxy
- 80% Human 20% Nuts/Bolts
01 Apr 2011 12:35
I like Mothers Aluminum Polish then touch up with Never-Dull wadding. If you want it to keep that shine with no elbow grease or time the solution is to seal the bike in Transparent Aluminum. See Scotty for formula. But I warn ya he's given oot all he's got... He kinna give oot na more!
here is what a bike in Transparent Aluminum might look like
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
01 Apr 2011 16:18
Or you could have Capt. Kirk fly it around the sun and take it back to the time it was shiny
- kzmitch
01 Apr 2011 17:00Kidkawie wrote: You can put a soda blaster together for under $10 and buy 3 large boxes of baking soda for $3 each. I wish I had my soda blaster when I put my 900 together, but I use it constantly on my other projects. I originally did my 900 by hand, the other week I sealed up the intake, took it outside and blasted away. Obviously had to wash all the soda off after, but it came out pretty good!
I can't quite tell. How does the air pull or feed the soda. Is that just a regular blow tip?
1978 KZ650 C2
- kzmitch
01 Apr 2011 17:04TeK9iNe wrote: Having a polished engine is nice and pretty if you like maintaining all that surface area on a regular basis forever. :blink:
I use my bike for daily commutes and keeping it clean is literrally impossible nonsense.
Just clean it real good and Gun-Kote it. Then cleanup is just a garden hose, a gentle scrub brush, and a quick ride/dry away
I dont have the time to polish/wax/elbow grease the shit out of her every week - TOO MANY OTHER TOYS!
Peace.
Just found that Gun-Kote stuff. Does it really work that well? I assume you used the brushed stainless or do they have a clear, too?
1978 KZ650 C2
01 Apr 2011 17:21 - 01 Apr 2011 17:50kzmitch wrote:Kidkawie wrote: You can put a soda blaster together for under $10 and buy 3 large boxes of baking soda for $3 each. I wish I had my soda blaster when I put my 900 together, but I use it constantly on my other projects. I originally did my 900 by hand, the other week I sealed up the intake, took it outside and blasted away. Obviously had to wash all the soda off after, but it came out pretty good!
Click > www.kzrider.com/forum/21-tools/318083-budget-soda-blaster
Click > kawpen.edebris.com/forum/viewtopic.php?f=9&t=2049
Click > www.aircooledtech.com/tools-on-the-cheap/soda_blaster/
Click > www.garagenight.tv/diy-soda-blasting-build-your-own-rig-cheap/
Last edit: 01 Apr 2011 17:50 by Patton.
