- Thank you received: 114
clutch question
- stonemaster
- Visitor
06 Mar 2011 15:25 #435646
by stonemaster
clutch question was created by stonemaster
installed cluch cable on my project and was checking it out. I can shift up one and back down one on my shifter but thats it, there is tension on the cluctch cable, it worked fine 5 month ago when it last ran, I havent put oil in it yet as I was considering disassembling the clutch, is this common for a bike thats been sitting for awhile for it not to be able to shift after sitting ? I did not have this problem on my other build but it was a brand new clutch
- stonemaster
- Visitor
06 Mar 2011 15:33 #435648
by stonemaster
Replied by stonemaster on topic clutch question
got my answer from a friend
- racer54
06 Mar 2011 18:38 #435721
by racer54
Replied by racer54 on topic clutch question
Well...what did you find out? Let us know so we all know in case we run into the same problem!
- testarossa
- Thank you received: 82
06 Mar 2011 18:44 #435725
by testarossa
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
Replied by testarossa on topic clutch question
Positive neutral finder should prevent you from shifting up past neutral if the bike is not rolling.
2004 ZX-10R
Angola, IN
- stonemaster
- Visitor
06 Mar 2011 18:48 #435727
by stonemaster
din,ding,ding we have a winner, I was confused based on my experience with my non metric build, with it I could change away at will
- wireman
- Thank you received: 299
06 Mar 2011 20:24 #435751
by wireman
Replied by wireman on topic clutch question
- bgmrc
- Visitor
07 Mar 2011 12:32 #435921
by bgmrc
Replied by bgmrc on topic clutch question
learn somethin new everyday about my bike!!
