Putting 750 cylinder on my 650B
- pete@PMH
06 Mar 2011 09:45 #435498
by pete@PMH
'79 KZ650C,
Re-Building '78 KZ650B
Putting 750 cylinder on my 650B was created by pete@PMH
I wondered if anyone knows if I can put a 750(four) cylinder on my '78 650B. I found a clean cylinder with four pistons online. Wasn't sure if i could rebuild changing just these components. (ie. will the cylinder go straight on and fir the block and head, do i need to change con-rods etc...?)
'79 KZ650C,
- steell
06 Mar 2011 14:43 #435639
by steell
Replied by steell on topic Putting 750 cylinder on my 650B
You need to make the holes in the lower case a bit larger so the 750 sleeves will slide in, and you can use the 650 head. If using 750 head and cams, install the 650 cam sprockets on the 750 cams.
Don't use GPz750 heads or cylinder blocks, 80-82 KZ750 blocks have provision for the roller cam chain of the 650, I don't know about later models.
- pete@PMH
06 Mar 2011 14:52 #435642
by pete@PMH
'79 KZ650C,
Replied by pete@PMH on topic Putting 750 cylinder on my 650B
Thanks for the info...
'79 KZ650C,
