cam clerance
- kzgeary
05 Mar 2011 20:32 #435376
by kzgeary
cam clerance was created by kzgeary
wanting to know the stock cam clerance for 79 kz1000 B3 ltd and is it possible when timing it to be 180 degrees off
- PLUMMEN
- Thank you received: 104
05 Mar 2011 20:35 #435377
by PLUMMEN
Replied by PLUMMEN on topic cam clerance
yes cams can be installed 180 out
bend something?
bend something?
- kzgeary
05 Mar 2011 22:04 #435399
by kzgeary
Replied by kzgeary on topic cam clerance
what do u mean by bend something
- TeK9iNe
- What did you do!?!
- Thank you received: 28
05 Mar 2011 22:10 - 05 Mar 2011 22:11 #435402
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic cam clerance
kzgeary wrote:
If you install them 180 out and give them a spin, you'll bend a valve. (Valve will collide with rising piston).
Ignition spark timing can be 180 off by either pickups swapped or plug wires/coil connections.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 05 Mar 2011 22:11 by TeK9iNe.
- kzgeary
05 Mar 2011 23:28 #435416
by kzgeary
but if u time it 180 with top dead center it shouldnt hit right bec we did it and the valves did hit
