best engine oil for the price
- gcarson64
05 Mar 2011 18:24
i am wondering what the cheapest reasonable oil is. i put royal purple in my low mileage bike, but i have another kz that is a low budget build ( the oil needs to be low budget also). so if you know what the cheapest reasonable oil is let me know thanks.
1980 kz550 38,500 miles basket case ( soon to be a BOBBER )
1983 kz550 9,600 miles
1988 jeep grand wagoneer 144,500 miles 4 mpg
Re: best engine oil for the price
05 Mar 2011 18:30 - 05 Mar 2011 18:36
Shell Rotella T Diesel Oil works for me.
It contains some zinc.
Last edit: 05 Mar 2011 18:36 by Patton.
- DoubleDub
05 Mar 2011 19:26
I'm planning on switching to this, but was eyeing up the Rotella T6 Synth, anyone using it? The only concern I had was the weight, as it looks like it only comes in 5w40, will that be an issue (I don't get the whole weight bit with oil...peoples tell me I should run 20w50).
- dejavoodo41
05 Mar 2011 20:10
The lower number is only a factor on cold startup. Once it heats up is is 40 weight. I have run 5w40 in my bike with good results. Now I run the Rotella T3 15w40 in my bike and my other 2 vehicles with great results.
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- DoubleDub
05 Mar 2011 20:17
Is T3 a bulk only product?
Is the concern that there would be too much initial wear with a 5w40 product?
- dejavoodo41
05 Mar 2011 20:37 - 05 Mar 2011 20:48
Nope that's the conventional 15w40 Rotella in the white bottle. I meant to say Rotella T Triple Protection. I know quite a few people that use the 5w40 with good results. I just prefer the thicker oil for the hot weather.
Last edit: 05 Mar 2011 20:48 by dejavoodo41.
Last edit: 11 Feb 2013 13:17 by martin_csr.
- bountyhunter
05 Mar 2011 23:20 - 05 Mar 2011 23:34
DoubleDub wrote:
They say that because the hi/lo visc ratio of 20-50 is only 2.5/1. With 10-40 it is a ratio of 4. In the case of 5-40, the ratio is 8 which means it takes a ton of viscosity increasing additives in the oil to make it do that. That's not necessarily evil, but bike engines (gearboxes) tear the VI's apart over time. When the VI's break down, you are just left with the base oil which is 5W oil in 5-40 multigrade, or 10W oil in 10-40. I generally use 10-40, but I dump it at about 1500 miles because it devolves to the base oil over time.I'm planning on switching to this, but was eyeing up the Rotella T6 Synth, anyone using it? The only concern I had was the weight, as it looks like it only comes in 5w40, will that be an issue (I don't get the whole weight bit with oil...peoples tell me I should run 20w50).
Last edit: 05 Mar 2011 23:34 by bountyhunter.
- bountyhunter
05 Mar 2011 23:23 - 05 Mar 2011 23:25
gcarson64 wrote:
You can get Rotella or Castrol GTX at Wally World in gallon jugs pretty cheap.i am wondering what the cheapest reasonable oil is.
Last edit: 05 Mar 2011 23:25 by bountyhunter.
- gcarson64
06 Mar 2011 20:18
thanks, i am going with rotella.
- Kitten Tooth
09 Mar 2011 17:35
i like the good ol' Castrol GTX:) nice clean golden sunshine
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
