shifter shaft seal kz 900
- deers45
- KZ 900
04 Mar 2011 17:46 #435058
by deers45
76 KZ900 DEERS45
shifter shaft seal kz 900 was created by deers45
can the seal where the shaft comes out of the engine case be pulled and replaced from the outside ?
76 KZ900 DEERS45
- gearheadmm
- MUCH MORE BOOST..........I mean BRAVO
- Thank you received: 11
04 Mar 2011 19:01 #435068
by gearheadmm
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
Replied by gearheadmm on topic shifter shaft seal kz 900
It can be done but it ain't easy...use a small SHARP punch and make two or four, start with two, evenly spaced small holes, or drill, around the outside of the seal in the STEEL just inboard of the OD. Then screw two small sheet metal screws opposite each other into the seal and pry out with a STRAIGHT pulling motion. Use hard screws like a auto trim screws. If the screws pull out of the seal try another set of holes or pry out with small screwdriver stuck in the holes. Collapsing the OD inward ,once you've exausted the screw method, will make the seal OD smaller or loose. Be carefull to not nick or damage the trans cover where the seal sits or the shift shaft. Inspect the new seal before you try it to get an idea of what your dealing with. GOOD LUCK! I have pulled many types of seals this way, smaller seals ARE more difficult.
- stonemaster
- Visitor
04 Mar 2011 19:17 #435073
by stonemaster
Replied by stonemaster on topic shifter shaft seal kz 900
the end of the shaft is square, does this complicate sliding the new seal on ????
- gearheadmm
04 Mar 2011 19:28 #435079
by gearheadmm
The outside end should have a spline
- stonemaster
- Visitor
04 Mar 2011 20:12 #435086
by stonemaster
ok my 73 is square so that trick may not work on mine if it ever becomes neccessary, just curious, thanx
- andy9802gt
- If it tastes that good, eat it yourself.
- Thank you received: 18
06 Mar 2011 10:46 #435512
by andy9802gt
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Replied by andy9802gt on topic shifter shaft seal kz 900
Just remove the trans cover it's not that hard. It's a damn sight easier than messing with that little bitty seal.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- deers45
- KZ 900
06 Mar 2011 19:03 #435731
by deers45
76 KZ900 DEERS45
Replied by deers45 on topic shifter shaft seal kz 900
will anything come out when you remove the trans cover besides oil
76 KZ900 DEERS45
- stonemaster
- Visitor
06 Mar 2011 19:08 #435733
by stonemaster
drain the oil first, follow FSM
