- Thank you received: 1
How will I know what shim i need?
- Treewizard
it couldn't have been to bad off, there was no loss of power before i took her apart = not like loss of compression would feel like.
so without spending a small fortune in guessing wich shims ill need. where would be a good place to start?
btw i have shim under buckets. so cams gota come off to replace shims >.<
thanks in advance!
=-John
1983 KZ 750 shaft
2002 ZRX 1200R
Raleigh NC
- PLUMMEN
- Thank you received: 104
figure what cleance you already have and subtract from what you need.
- Treewizard
1983 KZ 750 shaft
2002 ZRX 1200R
Raleigh NC
- PLUMMEN
were any of them checkable with a feeler gauge?
- PLUMMEN
subtract suggested clearance from what you have to get a ballpark number
- z1kzonly
- Thank you received: 540
- Treewizard
the lobes were pointed directly away from the bucket when i attempted to measure, and yes 2 or 3 of the clearences were within spec the rest were so close i couldnt fit the smallest feeler in the gap wich was like .08mm if i remember right
install with no shims is a great idea, will the raised spot in the inside of the bycket make contact with the valve stem? cause if it touches the retainer ill get a false reading right?
1983 KZ 750 shaft
2002 ZRX 1200R
Raleigh NC
- PLUMMEN
- larrycavan
- Visitor
@ plummen
.08mm is .003" That's too thick of a feeler gauge to have for your smallest. Got to Sears and get a new set that goes down to .0015" [everything is dual stamped these days for metric / sae.
- Treewizard
a .08mm not fitting would mean its out of spec anyway right?
im putting the block back together tomorow, so might start fiddling with clearances then
1983 KZ 750 shaft
2002 ZRX 1200R
Raleigh NC
