Chopping \"J\" Block
- Duck
- e vica na i sau na ga
28 Apr 2006 10:41
What is the difference in 'J' piston and KZ piston wrist pin centerline relative to the top of the piston?
Alternatively, how much do I need to take off a 'J' block to use KZ pistons and bring the top back up to 'normal' in the bore?
As best as I can tell it's looking like 1mm will do the trick.
Confirmation???
Is it OK to take this mm off the top or should I pull the liners and take it off the bottom?
Thanks,
-Duck
Confirmation???
Thanks,
-Duck
- APE Jay
Re: Chopping \"J\" Block
28 Apr 2006 16:40
It is closer to .055". If you take it off the top, you will make the o'ring groove shallow.
If you are using K pistons in a J motor, you will be down on compression because the J combustion chamber is larger, and the valve pockets are not right for the J head.
Jay
Jay
- Duck
Re: Chopping "J" Block
28 Apr 2006 17:17
Jay-
Thanks. I'm not doing anything yet. Still thinking about what to do. Pistons are in the photo. I'll try to measure how much of the J chamber they fill this weekend. I've already been advised to round off all the sharp edges on the top if I use them.
I may just save them and wait until a KZ motor turns up. They are very light weight.
Here is photo.
-Duck
Post edited by: Duck, at: 2006/04/28 20:46
Here is photo.
-Duck
