- Thank you received: 1
cloudy oil inspection window
- hypnohio
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
- 9am53
- homebrew, and some bbq
- Thank you received: 3
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- Jeff.Saunders
www.z1enterprises.com
Z1 Ent on Facebook,
- hypnohio
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
- bountyhunter
- Thank you received: 337
- Jeff.Saunders
You also need to change the oil more frequently:the condensation mixes with hydrogen byproducts to form acid which attacks metal parts. Modern oil has acid neutralizers but they get used up quick if you get water condensation a lot. This is also why "severe service" oil change intervals are sprcified at 3 months/3000 miles whichever comes first if you do a lot of short trips. It used to be called "taxi service" intervals. Oil is cheap, whenever it looks funny, dump it.
TOTALLY agree... on my turbo bike, I change oil AND filter every 500 miles... on my stock Z1A, every 1,000 miles...
I also run my fingers through the oil to see if I can feel anything in it. If I do find something I don't like, I chop open the oil filter to see what I can find. I had a broken cam chain guide on one bike I bought. The cam chain was chewing into the cylinder block and I found some very fine aluminum filings in the oil - and even more in the filter.
Z1 Ent on Facebook,
- mtbspeedfreak
- Thank you received: 36
What brand and weight oil do you run? I've never dissected my oil filter before, seems like cheap insurance, I'm about due for an oil change. Thanks for the tip!
2000 ZRX 1100
1976 KZ 900- Daily Driver
