only firing on two cylinders maybe?
- bvaleri
- Thank you received: 1656
- MFolks
- Thank you received: 540
I believe the caps should have 5K of resistance when tested with a multimeter. New ones are available at www.z1enterprises.com and I'd imagine at the motorcycle shops.
- bvaleri
- TeK9iNe
- What did you do!?!
- Thank you received: 28
i cant fit my spark plug wires from 1 to 4 i have two coils and each two wires are on the closest cylinder is that the problem?
YES.
Cylinders 1-4 on one coil, cylinder 2-3 on the other. If the bike wont start after, or backfires, you've got them backwards. Just switch the 1-2 wires, then the 3-4 wires.
Note the image: how the wires go from the coils... Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Thank you received: 2098
...83 kz550...cylinders...1 & 3 that not heating...new plugs...big blue spark...fuel and air...compression is 150 on all 4...unsure what else it could be....
What do #1 and #3 spark plugs look like? Real sooty? Clean as new? Or other?
Plug reading might help diagnose a possible carb issue such as for instance too high fuel level inside float bowls.
- bvaleri
- TeK9iNe
got it hooked right and 1 and 4 wont fire now but 2 and 3 are 3 wasnt before
Sorry, but are you sure that the wires coming out of one coil are going to the outside two cylinders? And the other coil has wires going to inside cylinders?
Just double checkin... cause you may have a dead coil, bad plug wire, bad spark plug, bad wiring to coil, bad ignitghter (if applicable), bad pickups and/or condensors...
More to check!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- bvaleri
