!@#$ I need new cases.
  • andy9802gt
  • Topic Author
  • If it tastes that good, eat it yourself.
21 Feb 2011 19:37 - 21 Feb 2011 19:42 #432578 by andy9802gt
!@#$ I need new cases. was created by andy9802gt
So I'm putting my motor back together this fine evening, get everything in the top half, put my three bond on the case, drop it over the studs, everything is fitting nice. Had a really small gap between the cases, tapped it down with a rubber mallet like it says to in the manual, torqued all the bolts starting with the crank first, flipped it over to put the upper case bolts in, start working around the starter and this opens up. So, who's got a set of cases that I can use for my '78 that are in good shape?
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Last edit: 21 Feb 2011 19:42 by andy9802gt.
  • andy9802gt
  • Topic Author
21 Feb 2011 19:43 #432579 by andy9802gt
Replied by andy9802gt on topic !@#$ I need new cases.
and another view
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
  • Stu Pidasole
  • if you aint mod'n, you aint rock'n!
21 Feb 2011 21:17 - 21 Feb 2011 21:21 #432593 by Stu Pidasole
Replied by Stu Pidasole on topic !@#$ I need new cases.
i am sorry about your misfortune, seriously i am. if i had a extra it would be yours....:( but keep OMR out of your garage.:laugh:
Last edit: 21 Feb 2011 21:21 by Stu Pidasole.
21 Feb 2011 21:22 #432595 by austin3119
Replied by austin3119 on topic !@#$ I need new cases.
Oh man.I'm sorry :(
  • trianglelaguna
21 Feb 2011 21:26 #432597 by trianglelaguna
Replied by trianglelaguna on topic !@#$ I need new cases.
bummer..pics dont show too good..words work ..but pics might help folks to guide you on a fix...
onward though...just have to comb the auctions..cases are everywhere on the fleabay imo....
might do better buying a junk kz or a engine..
scan craigslist and post a wanted add in your local craigslist.....
got anything good kz wise to trade?...might lure a lurker that has cases...good luck
sorry about your setback..no big deal..stuff happens right B)
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
21 Feb 2011 21:29 #432599 by austin3119
I agree. It seems like cases are an easy score compared to heads and cylinders at least.
  • andy9802gt
  • Topic Author
22 Feb 2011 01:33 #432610 by andy9802gt
Craig, I have a junk set of cases I can get rid of.:cheer: I know they are all over flea bay I just don't want to end up with the same thing again. It never made a noise so I think this crack was there when I tore it down or the cases got dropped at the blasters. The crack goes from the rear starter bolt down to the bearing on the back of the input shaft. I can see the locating pin in the bearing so I didn't miss it just broke.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
22 Feb 2011 01:53 - 22 Feb 2011 02:13 #432611 by PLUMMEN
Replied by PLUMMEN on topic !@#$ I need new cases.
dont throw them away,theyre good for mocking things up. B)
only cases i have apart right now are 2 sets of z1 cases,but i have frames that are close to both of them in #s im saving to build.
maybe try oldkawmans website to see what hes got B)
Last edit: 22 Feb 2011 02:13 by PLUMMEN.
  • andy9802gt
  • Topic Author
22 Feb 2011 02:04 #432612 by andy9802gt
only cases i have apart right now are 2 sets of z1 cases,but i have frames that are to both of them in #s im saving to build.
well take apart a set of KZ cases and send them my way dammit! ;)
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
22 Feb 2011 02:12 #432614 by PLUMMEN
i can send you a complete motor,shipping might be pricey though! B)
  • andy9802gt
  • Topic Author
22 Feb 2011 02:13 - 22 Feb 2011 02:15 #432615 by andy9802gt
lazy ass I'll take two. As long as you'll throw in some no crack case lube.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
Last edit: 22 Feb 2011 02:15 by andy9802gt.
22 Feb 2011 02:17 #432616 by PLUMMEN
how far am i shipping them and how fast do ya want to go? :laugh:
