1981 kz1000 ltd engine help
- tyhoppy
20 Feb 2011 18:24 #432224
by tyhoppy
1981 kz1000 ltd engine help was created by tyhoppy
A summary of my situation... My Exhaust cam sprocket came loose and wore the side of the head, resulting in some aluminum shavings and a broken timing chain. Upon disassembly i ended up cracking the case from my stupidity. The rotating assembly seems to rotate freely and the transmission all looks good. I have one bent valve. My dilemma is whether or not I should buy a used case and replace the bent valve and reassemble using my internals, or purchase a used motor for $750 plus mine as a core. I know I can get all the parts to fix mine for around $450. What do you guys recommend? Are my rod bearings going to be toast from the aluminum shavings? They feel tight. And should I have the rod bearings checked/replaced and fix this our buy the used engine?
I found some cases on ebay but some are j models, will these work on my k model?
Thanks
Thanks
- hocbj23
- Visitor
20 Feb 2011 18:55 #432233
by hocbj23
Replied by hocbj23 on topic 1981 kz1000 ltd engine help
J(standard),K(LTD),and M(CSR)81-82 bikes all use the same engine,except the cams on the J are a little more potent.It depends on whether u know anything about the used engine and the person ur getting it from.U could be buying more trouble unless they offer a warranty or something.On the other hand, u may have more damage than u think on your engine.Kind of a coin flip unless u just want to tear the motor down as a learning exercise.Good luck either way u go.
- tyhoppy
20 Feb 2011 19:02 #432235
by tyhoppy
Replied by tyhoppy on topic 1981 kz1000 ltd engine help
It's pretty much already completely torn down. I need some guidance on how to inspect for damage to rod bearing/main bearings or if it should be a concern or not.
- Old Man Rock
- Thank you received: 225
21 Feb 2011 03:31 #432292
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic 1981 kz1000 ltd engine help
Hey Ty....
FREE OEM Service Manual for ya... Will cover inspection, play measurements, inspections, re-build etc....
www.kawiworld.com/index.php?option=com_c...icle&id=77&Itemid=99
As for the cases, I feel your pain for same dumb ass thing I did in my first KZ build... Wasn't paying attention to details, miss read, trying to rush whatever...
Depending on the extent of damage, can be fixed or for me, just searched and found a another matched set of cases....
Good luck...
OMR
So you won't feel as bad... Here's my dumbass moment of the day.... :blush:
Good luck...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- tyhoppy
21 Feb 2011 05:56 #432314
by tyhoppy
I have that manual. But it says nothing that I can find about rod bearings... The rod bearings are my main concern. I found a couple sets of cases on eBay, and one is local to me.
How do you check the rod bearings?
- hocbj23
- Visitor
21 Feb 2011 06:36 #432322
by hocbj23
go to pages 3-18 and 3-19 in the service manual. It has pics and explanation on checking the rods and bearings--at least what little checking can be done.bj
- tyhoppy
21 Feb 2011 07:04 #432329
by tyhoppy
I read those pages last night. It says it checks for bending and twisting. Is that the only way to check the bearings? I'm worried that while tight now, some small amount of aluminum shavings could have found their way to the bearings, but might not have begun to wear the bearing yet. I rode this thing 15 miles with the exhaust cam sprocket rubbing against the head. There is a decent amount of shavings... Any ideas?
- hocbj23
- Visitor
21 Feb 2011 09:58 #432362
by hocbj23
No expert here,but if the engine is down already,why not wash the bearings and bearing surface with a high flashpoint solvent,blow dry,relube,turn em on your finger to see if u feel anything rough or gritty,and if not reinstall.Change the oil and filter,ride the bike for 50 miles or so,change the oil and filter again.Seems to me anything that doesnt wash out with the solvent will get trapped in the filter and will come out with the oil change.What about that-otherwise Im outta my league here and maybe Plummen,Patton or Larry C.can chime in and help..bj
- tyhoppy
21 Feb 2011 12:43 #432421
by tyhoppy
That's where my question is. It's not as simple as washing the bearings and surfaces with solvent, because the crank is pressed together. You guys that have experience with these rotating assemblies; should I be worried about aluminum shavings making their way to the rod bearings? And is it possible to flush them without dissassembly? What do you recommend?
- TeK9iNe
- What did you do!?!
- Thank you received: 28
21 Feb 2011 12:55 - 21 Feb 2011 12:57 #432426
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic 1981 kz1000 ltd engine help
Yes, the crank bearings can be cleaned up, just use a power washer and you'll be fine.
Make sure to spray it down with your favorite water displacer 40 or dunk it in some fresh oil immediately after your done.
...or take it to a balancing shop and have them press apart the crank, clean and balance/rebuild it, then your good.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 21 Feb 2011 12:57 by TeK9iNe.
- tyhoppy
21 Feb 2011 14:00 #432463
by tyhoppy
When you say crank, do you mean the main bearings or the rod bearings? I am aware that the main bearings can, because they are ball bearings. What about the rod bearings?
- Kraz1
21 Feb 2011 14:13 #432466
by Kraz1
Replied by Kraz1 on topic 1981 kz1000 ltd engine help
I sent you a PM.. Check that little Blinking Envelope by your name.
