KZ650 Shift drum removal, HELP!
- doped304
17 Feb 2011 16:53 #431344
by doped304
KZ650 Shift drum removal, HELP! was created by doped304
So the shift drum is the last hing I have left to strip from my lower cases so I can refinish them and it is kicking my a$$!
I took out the cotter pin from the 4/5th fork so it is free. I took out the plate held on by 2 screws as well as the snap ring.
In my manual it says to remove the screw that holds on the pin plate as well as the pins. That sucked even with a hand impact it took me forever to get the screw out destroying it in the process.
So now I am left with the shift drum stripped on both ends with the shift fork freely sliding on the drum.
So which side do I drive it out from, my crappy manual looks like I hit the end where the pins were. I beat the dog $hit out of this thing and it did not budge, what am I missing here?
- Nebr_Rex
- Thank you received: 300
17 Feb 2011 18:20 #431388
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic KZ650 Shift drum removal, HELP!
One bolt
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- doped304
17 Feb 2011 20:07 #431414
by doped304
Replied by doped304 on topic KZ650 Shift drum removal, HELP!
I am a dumbass sir! Got it.
