Cam Timing kz750 l3
- mbsween
Cam Timing kz750 l3
25 Oct 2005 21:29
I'm in the processes of putting the l3 back together. I recently installed an 810 kit.
So I get to the cam timing part, which always scares me, so this time around I took a who;e bunch of pics, which are at
www.bike-night.com/bbs/index.php?showtopic=235&st=0entry2236
Take a look and let me know if you thinkl I got it right
Thanks
Matt
Here's a shot of the timing , the 1 and 4 pistons are at TDC
Post edited by: mbsween, at: 2005/10/2600:30
Post edited by: mbsween, at: 2005/10/26 00:35
Thanks
Matt
- Walt
Re: Cam Timing kz750 l3
26 Oct 2005 08:26
Sorry to say that your intake cam is off. The exhaust cam looks ok but I count the intake cam mark line at between 46 and 47 pins should be between 45 and 46. I counted twice.
- luvmykaw
26 Oct 2005 11:53
I found it much easier to get a visual reference after I used a paint marker. You know, the type that salvage yards use for marking parts. I used yellow on the cam sprocket arrows and the cam chain pins. Ignore the red crap on the sprocket, it was a learning process for me.
- mbsween
27 Oct 2005 12:31
Chris is your chain tensioner in for that pic? I'm wondering what it looks like before the valve cover is on
- mbsween
27 Oct 2005 12:36
Walt,
it must be the angle. I've counted it a bunch of times and I get 23 links between the Ex and IN lines, which is pins 45 & 46. I've gone over it about 20 times.
Now you've got me counting them ago
I can't wait to start this thing!
- luvmykaw
27 Oct 2005 14:30
mbsween wrote:
To my eye you're dead on, between 45 and 46 pins, with both cam sprocket guide lines horizontal. The picture that you have here is not very good. Last winter I just bolted my cam chain tensioner back on and my cam chain guide, then cycled the engine (always forward, never backward) without the valve cover on it. I cycled through enough times until I was satisfied that everything was lined up correctly.........I had to do this because I screwed things up quite nicely at first. I took my cam chain tensioner off and cam chain guide out, well, just to look at them.:huh: Then I was doinking around turning the engine with a 17mm wrench off the bolt by the points plate. I went forward, backward, forward, then... I noticed some weirdness with the cam chain. When I was going backward, the cam chain was bunching up and jumping teeth. Master mechanic that I am, I got the engine so out of time that it would lock up with about a quarter wrench turn. I was going to change the cam chain anyway, so I did that, then I had to fiddle with lifting the new cam chain andturning the cams several times, until I had everything all lined up again. I used the yellow paint to make it easier for me to count the pins and see that the cams were positioned correctly.
Walt,
Now you've got me counting them agoI can't wait to start this thing!
- mbsween
27 Oct 2005 14:55
Chris,
thanks, there's a good version of that pic at
kz.mbsween.com/media/cam-timing-final-big.jpg
Its way to big to post tho. Thanks for the info, I've done the whole turn the engine the wrong way before, you really have to make sure to take up the slack with your fingers or a handle or something before turning it over.
Matt
Matt
- luvmykaw
27 Oct 2005 17:51
This thread is pertinent to your situation, as your bike has a different cam chain guide/tensioners than mine. These guys have infinitely more experience than I do. So maybe check out the thread below, it's in the Engine forum.
First time GPz1100 valve clearance-timing work. Could use some voice of experience... - 2005/10/25 13:24
