- Thank you received: 20
gpz cam specs
- nads.com
14 Feb 2011 22:38 - 14 Feb 2011 22:40 #430772
by nads.com
gpz cam specs was created by nads.com
Anyone know the op. and cl.#'s for a GPZ1100/ lobe centers and compression? This is with or without stock cams.
I'd like to get an idea of how the motor rev's to 10,000 with the centers it has, how early it opens, closes, overlap, the whole nine. I know already it has a peak up high.
Dave. You cheater, you went up two in the rear!!
No wonder your keeping up with busa's, you only weigh 100lbs.
100mph and your done though? :ohmy:
a 5grand kick then that's it?
The race doesn't start till then :woohoo:
I think I'm on the right track here, it's not the one at the amusement park.
Who was that said they had short centers once and it had nothing on top? :blink:
Shut the intake! Hurry! before the monster gets in!
:woohoo:
Go BS34's!! :woohoo:
:woohoo:
Last edit: 14 Feb 2011 22:40 by nads.com.
- meds
15 Feb 2011 01:24 #430776
by meds
Replied by meds on topic gpz cam specs
Are the bigger than the cams in my 73 900?
- larrycavan
- Visitor
15 Feb 2011 04:40 #430788
by larrycavan
Replied by larrycavan on topic gpz cam specs
