- Thank you received: 540
"Dyna S" for Z1 Can you bench test these units?
- z1kzonly
14 Feb 2011 17:51 #430703
by z1kzonly
"Dyna S" for Z1 Can you bench test these units? was created by z1kzonly
I have a couple of Dyna S ignitions. Was wondering if there is a bench test to see if they are good or bad?
Don't have a complete runner to test it on at the moment.
Thanks
Thanks
- Thank you received: 2098
14 Feb 2011 17:58 #430707
by Patton
Replied by Patton on topic "Dyna S" for Z1 Can you bench test these units?
Is the Dyna-S rotor available?
- trianglelaguna
- Thank you received: 235
14 Feb 2011 18:09 #430711
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic "Dyna S" for Z1 Can you bench test these units?
never seen a bad one..those are extra clean...they work...bet a 100 bucks?
1976 KZ900
2003 ZX12R
2007 FZ1000
14 Feb 2011 18:10 - 14 Feb 2011 18:11 #430712
by Patton
Last edit: 14 Feb 2011 18:11 by Patton.
- loudhvx
- Thank you received: 1616
14 Feb 2011 19:51 #430746
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic "Dyna S" for Z1 Can you bench test these units?
Do you have a battery, a small magnet, a coil and some wire?
That's all you'd need to bench test it.
1981 KZ550 D1 gpz.
Other links.
- Old Man Rock
- Thank you received: 225
15 Feb 2011 03:06 #430780
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic "Dyna S" for Z1 Can you bench test these units?
Same principle as static test but only out of engine...
Instead of crank rotor magnet, use small magnet in hand to activate...
To go along with what Loud depicted....
Not sure you truly need a coil to measure the 12Vdc to the coil. Possibly requires a load but maybe not...
+12Vdc and ground to the plate, place the magnet near one of the sensors and measure for +12Vdc (battery voltage) on the associated output conductor Black or green...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- z1kzonly
15 Feb 2011 07:54 #430827
by z1kzonly
Replied by z1kzonly on topic "Dyna S" for Z1 Can you bench test these units?
Thanks for all the info!
I can come up with all the stuff. I have a high end multi-tester from around 20 yrs ago. Batt. powered, digital read out, it beeps if you can be in sight of it.
Only thing, I am not shure on the diode reading and setting.
Thanks
Marty
Thanks
Marty
- loudhvx
15 Feb 2011 09:12 - 15 Feb 2011 09:14 #430850
by loudhvx
1981 KZ550 D1 gpz.
Other links.
The reason I'm saying you will want a coil is you want to make sure it sparks solidly up to 1/2". Don't try to jump more, though, because that can damage the dyna S.
The primary side of the coil, that the Dyna S is trying to ground and unground, will have a spike near 400 to 600 volts at the moment the Dyna S ungrounds it. Simply checking voltage levels will confirm the Dyna S is trying to turn the coil on and off, but without a coil and spark, you can't really confirm it will withstand the spike necessary to produce the spark. A common failure mode of ignition drivers is to still turn on and off, but not be able to withstand the spike. That's what you test for by getting an actual spark.
1981 KZ550 D1 gpz.
Other links.
Last edit: 15 Feb 2011 09:14 by loudhvx.
