- Thank you received: 72
Engine tip of the century?
- turboguzzi
As i will soon have to shim my valves for the Andrews cams, I asked a fellow racer who runs a KZ1000 in vintage road racing where does he source his shims in Italy.
Well, he discovered that quite a few european cars have 13.42mm diameter shims and that he can get used ones almost for free from friendly car mechanics as most of these car models are a bit obsolete. he's been using these shims for the last four years without issues.
using them only requires enlarging the cavity in the retainer by .5mm (stock are 13mm) and your set... good for 650's, 750's, 900's etc...
look for the 13.42mm ones in the list under Citroen, Fiat-Lancia, Peugeot, quite nice size range too for big clearances
enginepartsuk.net/shims.pdf
And send me a penny for each one you get
- gearheadmm
- MUCH MORE BOOST..........I mean BRAVO
- Thank you received: 11
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
- Jeff.Saunders
Early Ford Taurus SHO engines, Yamaha, use shims that fit KZs too. Over bucket 900s an 1000s
Those 29mm shims do fit, but the shims have a hole in them... ...I've been reluctant to install any in my engines - although what is nice is they come in smaller increments.
www.z1enterprises.com
Z1 Ent on Facebook,
- dejavoodo41
- Thank you received: 14
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- bountyhunter
- Thank you received: 337
- turboguzzi
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Thank you received: 2098
Seems logical that a hole would be even worse than a dimple.
The first Z1 shims had a center dimple (or naval) which might possibly cause it to crack, and which was superseded early on by a non-dimpled version, with recommendation that any such dimpled shims be replaced.
Click > kzrider.com/index.php?option=com_kunena&...ew&catid=2&id=349888
- gearheadmm
- larrycavan
- Visitor
Even the OEM 13mm shims fracture. I've see many of them in motors I've torn down over the years. Those bikes all lived a hard life
If anyone is going to try to run real thin shims with S.O.B. setup, be careful! The shim should never set below the retainer any amount greate or equal to the button thickness on the bottom of the bucket....and even that is pushing your luck
- PLUMMEN
- Thank you received: 104
yeah seems like that would be a recipe for pushing down the retainer and losing a keeper at high rpms. eeeek! :SPatton wrote:
- Jeff.Saunders
Z1 Ent on Facebook,
