Open element filter options, 2 or 4?
- notaduc
10 Feb 2011 17:57
I am curious if anyone has input or opinions on 4 single pods vs 2 double filters for 4 carbs?
1980 (mostly) KZ1000
- Polar_Bus
Re: Open element filter options, 2 or 4?
11 Feb 2011 06:34 - 11 Feb 2011 09:01
notaduc wrote:
NEITHER ! As always, my attitude is if you have a fairly stock street driven bike keep the stock airbox !!!! If you don't have any tuning experience and you swap to pods you are headed for a lifetime of tuning misery.
Bikes:
'84 GPz1100
'06 HD Fatboy
'84 GPz1100
'06 HD Fatboy
Last edit: 11 Feb 2011 09:01 by Polar_Bus.
11 Feb 2011 07:41
I think that could cause problems. I believe that the intake events for 1 & 2 and 3 & 4 overlap. Toward the end of the intake cycle on cylinder 1, the intake cycle for 2 begins. Assuming there is more resistance pulling through the filter media than from the neighboring cylinder, this could allow cylinder 1 to draw from #2, thus allowing only a partial charge to enter #2 after the intake valve on #1 closes. Having individual filters or short runners into a large intake box would prevent this.
I have seen a single "pod" filter for all 4 that perhaps has just enough plenum effect to prevent this. On the other hand, this may be why such mega-pods fell from favor.
Just my .02 theory..............
11 Feb 2011 08:24
Polar_Bus wrote:
+1
notaduc wrote:I am curious if anyone has input or opinions on 4 single pods vs 2 double filters for 4 carbs?
NEITHER. As always my attitude is if you have a fairly stock street driven bike keep the stock airbox !!!! If you don't have any tuning experience and you swap to pods you are headed for a lifetime of tuning misery.
+1
- notaduc
11 Feb 2011 14:49
It is not stock at all as far as the bike is concerned, but the motor will be mostly stock.
It is for a complete custom, that will not be a daily.
As far as tuning, I will be playing with jetting plenty anyway with the carbs I am using, and have battled plenty of other jetting mysteries in the past, and am aware that pods are tougher than stock.
The overlap issue more or less answers my question.
I remember seeing a post on here somewhere with a guy with vm29's and some other craziness that was running paired filters that seemed to have his setup dialed...
11 Feb 2011 20:00
notaduc wrote:
Click > kzrider.com/index.php?option=com_kunena&...d=3&id=245889#245971
Scroll down to post by guitargeek, and following.
12 Feb 2011 14:47
Guess my expensive theory may be faulty, though I wonder what advantage two siamesed filters have over four singles.
- TeK9iNe
- What did you do!?!
12 Feb 2011 15:33
Just more air, far as the manufacturers say. Its a larger surface area to draw from.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
