kz750f clutch issue
- dms_photo
- Thank you received: 2098
I went to install a new clutch cable today and ran into a problem. Where the little knob on the end of the cable attaches to the clutch, there is an arm that pivots. When the handle is pulled it pulls this piece towards the front of the bike. The problem is, this arm has no springiness to it, so it doesn't return towards the back of the bike. It is just able to be moved freely, and i'm assuming this piece should have a spring of some sort that creates tension. Am i missing something?
92081A
92081-1486
SPRING, CLUTCH RELEASE
[Click on image to enlarge view.]
Would closely monitor the dealer's parts order because it's easy to confuse the needed part with similarly numbered part 92081-1176 CLUTCH SPRING, also available.
- treitz
I ended up pulling one from a bike at the local junk yard.
I have my original that I could send u. It's a little bent, but may still work when installed.
If it doesn't work I could look for one at the junk yard for u next time I'm there. Assuming u can't find one of course.
1979 KZ400 - 2-1 Manifold - Mikuni VM34
- dms_photo
Treitz- It's not discontinued apparently. Thank you for the offer. I really appreciate it.
- dms_photo
Anyway, I took it for the first ride today even though it was aboout 30 degrees outside. Thanks for the help guys.
- treitz
