Sound padding
- TomW
- Keep the blue side up.
Sound padding
10 Feb 2011 11:52
Anybody got a cheap solution to replacing the sound pad under the sprocket cover on a KZ1000? The old one is dis- corporated and new ones are $43.:ohmy: (ouch!) Or do you guys just leave it out and put up with the noise from the chain?
'78 KZ1000B2 LTD stock + Vetter Fairing & luggage
'91 ZG1200B5 Voyager XII, stock
- andy9802gt
- If it tastes that good, eat it yourself.
Re: Sound padding
10 Feb 2011 12:12
leave it out the chain isn't that noisy.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
Re: Sound padding
11 Feb 2011 08:29
If you find the chain noise bothersome, just remove the baffles from your mufflers. :laugh:
- TomW
Re: Sound padding
11 Feb 2011 09:19
I could turn up the volume on the I-pod too.
Re: Sound padding
11 Feb 2011 11:47
i had to remove mine because i have an offset sprocket but, i could not tell any difference in noise with or without.
Re: Sound padding
11 Feb 2011 12:13 - 11 Feb 2011 12:30
Was just another effort toward meeting EPA noise standards.
Would toss the padding along with the air injection paraphernalia (where fitted) and pilot screw plugs. :lol:
Last edit: 11 Feb 2011 12:30 by Patton.
- hocbj23
Re: Sound padding
11 Feb 2011 13:26
If u really want to replace it,go to local hardware and get some foam pipe wrap.cut into strips and glue (or not) to the cover.I had to redo mine and thats what I used.Whoever said the chain isnt noisy under that cover has worse hearing than mine and mines BAD.Lol.bj
- larrycavan
Re: Sound padding
11 Feb 2011 13:33
hocbj23 wrote:
I run mine without that padding because of the offset sprocket. Not noisy. Maybe it's your chain that's bad or too tight.
What did you say, I can't hear you?
- hocbj23
Re: Sound padding
11 Feb 2011 13:56
x ring with less than 400 miles on it adjusted to spec.Tried the cover without the padding and it was pretty consistent hi-pitched whine.Much less with padding.What?Eh? Damn,speak up boy,can hardly hear ye.Aw,shit,fergot to take me earplugs out.Lol.bj
- TomW
Re: Sound padding
12 Feb 2011 09:17
30 yrs. in commercial construction, trap shooting, informal target shooting, 21 yrs. shooting display fireworks, and old age age has taken a toll on my hearing also. Huh? What's that you say, son? I CAN"T HEAR YOU!!!!
I'll leave it out. If'n I see or hear a need, it's an easy fix later.
