Oil Inside the Alternator Cover
- jackflack
09 Feb 2011 21:35 #429725
by jackflack
Oil Inside the Alternator Cover was created by jackflack
How much oil should you expect inside the alternator cover? I get a regular drip and am not sure whether it is because there is oil inside the cover or the cover is not sealed well.My understanding is that some oil gets pumped in during normal use to oil the starter gear and cool the stator.
- PLUMMEN
- Thank you received: 104
10 Feb 2011 00:36 #429728
by PLUMMEN
Replied by PLUMMEN on topic Oil Inside the Alternator Cover
yep its supposed to have some oil in there,either a gasket is leaking or the plug where wires go into it
- Thank you received: 2098
10 Feb 2011 02:45 - 10 Feb 2011 02:51 #429732
by Patton
Replied by Patton on topic Oil Inside the Alternator Cover
Click >
Replacement grommet from Z1E
Including information about bike year and model may elicit better responses. And it's easy to put in your signature where it will automatically appear in posted messages.
When done, the signature information appears in all posts, past and future. And may be changed as often as desired.
Here's how to do it:
Click > Adding Info to Signature
Last edit: 10 Feb 2011 02:51 by Patton.
- loudhvx
- Thank you received: 1616
10 Feb 2011 09:57 #429771
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Oil Inside the Alternator Cover
Some KZ's run a totally dry charging system, (nicer to work on) and some have a little oil access to it for cooling I guess.
1981 KZ550 D1 gpz.
Other links.
- keith1
10 Feb 2011 18:08 #429878
by keith1
Replied by keith1 on topic Oil Inside the Alternator Cover
PLUMMEN wrote:
i m with him......i got a fin says the grommet is toast...easy fix.....get a grommet and a gasket and its an hour job drinking suds......:laugh:
