valve seals
- Bugg
valve seals
26 Apr 2006 18:07
my kz was sitting for about 10 years before I got to it and it seemes to run fine except it smokes a bit most noticibly on idle, I have heard the the valve seals go with age so I'm guessing thats it, how difficult are they to replace, and are they a major problem if it's run in this condition. or do they plump back up with use (its gone maybe 100 miles since I bought it)
also, the bike while it runs quite well, doesnt really seem to be able to really go faster than 80, however I can't say this for sure as I haven't really had a couple miles worth of open road to test it, but it sure feels like its giving its all at that point, am I just overestimating what it should be able to do, or does it just really need alot of space to wind out in top gear?
- loudhvx
Re: valve seals
26 Apr 2006 18:16
When it's all good, it should get near 100. I had one that went over 100 according to the speedometer, but I don't really know how fast that was.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- KZQ
- Administrator
Re: valve seals
26 Apr 2006 18:23
There might be more in there but it'll take a fresh engine to see it, at least a top end. Once you see it, clean oil will maintain it!
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- Bugg
Re: valve seals
26 Apr 2006 18:49
just topped it off with some fresh oil, it had obviously sat for awhile with the fuel on as the oil i had originally was contaminated, the oil I just pulled out was real dirty, and I went with 15/30 to try and slow the smoke,and it seemed a little better, how would 20 wt go? would it drag the motor? to be honest, if its not gonna hurt the engine, it feels like im back on a 2 stroke:woohoo:
- gas
- brianrae33
Re: valve seals
27 Apr 2006 20:27
what size is it...550...650...750...etc....i had a 77 kz 650 bone stock that would hit the ton quite easily...now running a 78 ltd1000 that will see 100++ in third....
1982 kz1000ltd
